Throwing codes with Edge Attitude
Old May 8, 2007 | 08:01 AM
cincydiesel's Avatar
Yesterday I was hooking up my motorcycle trailer and noticed the trailer lights were not working. So I decided to check the fuses, sure enough I had a blown trailer running lamp. In the process of changing the fuse I some how disconnected the 10amp transmission relay fuse that my Edge Juice is tapped to. Without noticing I did this I drove about 20 feet and noticed the engine light was on. I amediatly checked for codes and the ecm is throwing about 15 codes. I noticed that the Attitude was not on so right back to the fuse box I go. I then noticed that transmission relay and Edge were disconnected. I plugged everything back up however the codes are still there and the engine light went off but not right away. The codes were not there in the morning because I have been checking every morning as a precaution since I just installed the Edge a few days ago. I'm sure the reason for the codes is because of the transmision relay fuse being pulled however the codes will not go away. The truck is running great, do I need to worry?
Old May 8, 2007 | 12:12 PM
Dodgezilla's Avatar
I think you will be fine. Plenty of us have unhooked stuff mistakenly and thrown codes. It will clear itself. If the truck is running fine then don't worry about it.....
Old May 8, 2007 | 01:18 PM
How long does it take to clear itself?
Old May 8, 2007 | 02:57 PM
Dodgezilla's Avatar
Actually, you can just go to AutoZone and they can clear the codes for you for free I think. I was referring to the CEL clearing itself. I'm not sure how long the codes will remain in the computer's memory....
Old May 8, 2007 | 04:06 PM
IF I do have to take it back to the dealer I will have to take everything off. However I cant take off the EGT probe. Will that alone viod my warranty?
Old May 11, 2007 | 12:19 AM
cumminspower79's Avatar
Im not sure about the third gens but I think the second gens clear after about 50 starts or somthing like that. Its probebly the same way.
Old May 11, 2007 | 01:02 AM
Juiced06's Avatar
I believe Edge w/Att moniter clears codes for you just scroll down to clear and retrieve codes and follow instructions
Old May 11, 2007 | 02:57 AM
madhat's Avatar
Administrator/Jarhead
That must be on the newer ones, cause mine does not do that...
I would not be worried about the codes. Let autozone clear them, then check the next day to see if any of them have came up. My vote is no, but better safe than sorry.
Old May 11, 2007 | 09:47 AM
Yeah,
Mine doesn't have that either. However my friendlly mechanic cleared them for free and they yet to re-apear.
Old May 17, 2007 | 04:29 AM
Juiced06's Avatar
Yes this may be true seeing as you guys have an 05 and 04.5 mine is 06 and also came with turbo timer
abb
Jan 11, 2006 05:48 PM
ssleeper94
Nov 11, 2005 11:47 PM
Flatty
Jun 13, 2005 01:59 PM
gatf4
Mar 22, 2005 02:00 PM
Sarge1124
Sep 2, 2003 11:02 PM
