is throttle sensor screwed
Old Dec 24, 2006 | 08:37 AM
3500eh's Avatar
have 03 3500. just replaced tranny and majority of front end. never in accident. now when i put in gear engine makes noise and have to really hold brake or truck goes. gets up to 30 without touching throttle. whats wrong now? tranny again? throttle sensor? any ideas what i can do. have to go to work out of town befor i can get to shop. truck runs fine once let off brake.
Old Dec 24, 2006 | 02:05 PM
RCW's Avatar
RCW
I would suspect the throttle valve cable is forcing the throttle linkage open a bit. That is a transmission valve body failure if the truck starts and runs fine in park or neutral and then revs up when you put it in drive.
Old Dec 24, 2006 | 04:36 PM
AlpineRAM's Avatar
What's your idle speed?
Does the idle speed change if you put the transfer case in neutral (assuming 4x4) or lift the rear axle when you put it in gear?
AlpineRAM
Old Dec 25, 2006 | 10:24 AM
3500eh's Avatar
i checked for the code. p0633 came up, problem with skim key. just had command start put in. must have something to do with, hopefully. will talk to the guys who installed it. hope thats it.
Old Dec 26, 2006 | 12:33 PM
3500eh's Avatar
the code for skim key is not what the problem is like i thought. rear of truck lifts when i put in gear and rpms only slightly move but go back to normal. sounds like motor is under lot of stress until i let of brake. help. i gotta go 600km to work in the am and not able to find a mechanic until its to late
Onemoparnut
Aug 19, 2013 08:11 PM
Mallard
Apr 9, 2007 12:59 AM
Jake R.
May 24, 2006 10:23 AM
FastSS
Nov 10, 2003 10:00 AM
FastSS
14
Nov 15, 2002 07:51 AM
