Is my transmission screwed?
Old Nov 8, 2003 | 11:36 PM
FastSS's Avatar
So I'm driving along tonight and every once in a while it will try to downshift with very partial throttle and end up falling back into the gear it was just in, it will do it over and over again for about 5-6 times then just stay in the gear it started in
im talkin like trying to down shift at 10-15% thtl on a flat road ~60mph
Old Nov 9, 2003 | 09:05 AM
J BODY's Avatar
Re:Is my transmission screwed?
Is the trans actually downshifting or drifting in and out of lockup?
Old Nov 9, 2003 | 09:43 AM
PourinDiesel's Avatar
Try the "happy box" listed on Ebay.
It addresses the voltage issues that would cause erratic lockup.
--Justin
Old Nov 9, 2003 | 08:51 PM
FastSS's Avatar
you bring up an interesting point, it kinda feels like its just letting go for a second then grabbing back on
there *seems* to be a connection between doing it more often with my KC lights on (two on front grille) and less/not at all with them off... also I noticed that my "check gauge" light stays on when I start the truck because the battery voltage is too low... my outside air temp sensor also often displays values that are way too high... or just "SC"
funny how it does all this after a repair shop shorted the alternator to the chassis and popped the main fuse
Old Nov 9, 2003 | 09:35 PM
Scubasteve's Avatar
You should really checked your voltages etc before going any further. sounds like the boys at the shop made an oops.
Another thing to consider is are both the batterys still good. I am going to go with the torque converter locking and unlocking. does the engine light stay on all the time? if so I would take it to your local NAPA dealer and have them pull the codes.
Good Luck
Jason
Old Nov 10, 2003 | 09:53 AM
FastSS's Avatar
no cel at all
Batts are both optima red tops replaced last year and never deep discharged =( I really hope one of my batts isnt dead those fockers are expensive
Old Nov 10, 2003 | 10:00 AM
DPG's Avatar
DPG
FastSS, Sure sounds like your TC is going in and out of lock-up like mine did. DTT has an electronic noise filter for $35.00 U.S. that takes care of the problem. Did for me.
DeWain
axpilot
Jul 5, 2004 07:29 PM
Jeremy Cusick
May 31, 2004 01:42 PM
jawmail
Apr 16, 2004 11:17 PM
FastSS
14
Nov 15, 2002 07:51 AM
