93 VE pump leak
Old Dec 25, 2006 | 06:35 PM
robjohn's Avatar
Unhappy 93 VE pump leak
My 93 VE pump has a leak at the governor shaft nut. Just above the mounting flange. Is it possible to access this by loosening mounting bolts and sliding back. I sure hate to remove the pump for one little o-ring.
Thanks
Old Dec 25, 2006 | 09:28 PM
RCW's Avatar
RCW
If this is the seal I am thinking of you can get to it from the outside, but it is not a standard O-ring. It is a square shouldered seal made specifically for Bosch, and an O-ring will not work.
Old Dec 26, 2006 | 03:26 PM
The pump has to come off.
bflood
Dec 29, 2019 06:05 AM
coalburner_77
17
Nov 7, 2018 07:36 PM
Bobcat698
Nov 21, 2005 09:19 PM
Lightman
16
Jan 21, 2004 10:46 PM
amartinson
0
May 4, 2003 01:55 PM
