Tach going crazy
Old Feb 12, 2007 | 05:48 AM
Tengu's Avatar
Tach going crazy
So I am driving along and I see the tach jumping a little bit. I think "man, I just replaced the VP 15k ago!" It goes away.
A few weeks later I get a "check engine" light. 3 key cycles later it is gone. It did this again the next day. It goes away.
So the other day I am on the second leg of a 1 hour drive and the tach starts jumping wildly. The noise from the engine is not matching up to what the tach says. The only change in the engine is that a few times it dropped to 0 and I could hear the engine start to cut out.
It was like -2 outside so some say fuel could be the issue. I have a post filter gauge that is showing just under 10 psi and I had been driveing for over a 1/2 hour with 1/2 tank of fuel. I did not get a "water in fuel" light, so I did not suspect that.
I have noticed that it has been having a hard time getting into overdrive in the last week but I atributed that to the -10 weather and needing to get warm. Once it is up to temp this goes away. I must admit though that it has not done this before the last few weeks.
When I got off the highway and on secondary roads the problem seemed to go away. On my way to the repair shop this morning it ran fine.
Any thoughts?
Old Feb 12, 2007 | 06:43 AM
Tengu's Avatar
ANYONE?? I am going nowhere fast...
Old Feb 12, 2007 | 06:51 AM
Totallyrad's Avatar
I saw a post just yesterday about a similar situation. He cleaned his battery connections and his issues got better.
Old Feb 12, 2007 | 06:38 PM
slim51015's Avatar
A cam or crank sensor affects the tach. sometimes. Get the codes read with a scanner.
Old Feb 12, 2007 | 09:26 PM
dltriolo's Avatar
possibly ctm
Old Feb 12, 2007 | 10:22 PM
53 willys's Avatar
"key on key off" for codes???
Old Feb 12, 2007 | 10:27 PM
pull's Avatar
This kind of happend to me It finally went away after I cleaned all the grounds I could find.
Old Feb 13, 2007 | 05:19 AM
Tengu's Avatar
When they looked at it at the shop they said that the battery terminals were loose. I hope that fixes it. I will know after work today. Thanks.
Old Feb 13, 2007 | 08:39 AM
J BODY's Avatar
Did they hook a scan tool up? It should have had a stored code in one of the controllers. Hope the batterys were all it was.....but I have my doubts.
74dart
Feb 19, 2011 06:38 PM
silverbullet02
Mar 15, 2007 05:17 AM
Atlantic4x4
Sep 8, 2006 09:20 AM
rebal
Jan 27, 2005 09:00 AM
