striped bolt tricks
Yup. Snap-on has sockets that are made to grip the bolt or nut when they are stripped. They work great and will work with a impact wrench. I use them daily.
If you can drive one on the bolt it will take it out or break the bolt.
All the suggestions above are good. Welding a nut on has an additional advantage in that sometimes (sometimes, not always!) the heat can loosen rust etc.
If you use the welded nut method Make sure you put a little water on the nut after you weld to cool the bolt a little so it does not just twist and brake the bolt off when hot.
I use this method at least twice a week at my job,works great.
dslpwr81
Mar 10, 2008 09:05 PM
J Cook
Dec 24, 2007 03:01 PM
