engine running
Old Apr 10, 2007 | 08:02 PM
bloodhound51's Avatar
engine running
89 non-intercooled 12v
when i put 12 volts to the kill switch it fires and revs up not uncrontrollably just to the governed limit
if i take the 12 volts off the kill switch it idles
if i give it throttle the engine dies
no fueling mods are done yet
what could cause this there is only smoke upon startup then it clears at idle there is no smoke i am clueless
any help is greatly appreciated!!!
Old Apr 11, 2007 | 04:52 PM
Sounds like a pump problem. If you haven't been in there and this just started out of the blue, something's broke.
Old Apr 11, 2007 | 08:17 PM
problem is solved
we took away some fuel which is suspicous since the engine as far as i know
had not been turned up even though the collet nut had been ground off.
and it idled right down.
runs great now.
VERY SCARY i don't like choking my turbo hahaha
builtnotbought1
Jul 6, 2014 09:49 PM
black&blue
Feb 18, 2009 08:32 PM
steveb
17
Jan 24, 2004 10:15 PM
Hummin Cummins
Oct 29, 2003 07:19 PM
PapaSmurf
Sep 10, 2003 10:21 PM
