Stranded in Madison Ga
Old Apr 6, 2006 | 07:33 PM
  #46
Shovelhead's Avatar
Administrator / Scooter Bum
HUGE BUMMER Herb.
Your drivers do know what an EGT gauge is for, don't they?
Old Apr 6, 2006 | 08:11 PM
  #47
herb's Avatar
HUGE BUMMER Herb.
yes, my son is the only other person who drives our trucks and he is dilligent about watching the gauges and takes excellent care of the vehicles.
Any way to check injecter pump for defect ?
Old Apr 6, 2006 | 09:20 PM
  #48
Shovelhead's Avatar
I'm curious how the pistons can get hot enough to melt without showing high EGTs,....
Maybe the plastic oil jets in the block that shoot oil under the pistons to cool them came loose on yet another engine?
Old Apr 7, 2006 | 08:42 AM
  #49
Diesel-Dan's Avatar
YES...i should have been more clear....Newer the better ment up to '02 (ISB).......My bad......
Old Apr 7, 2006 | 01:56 PM
  #50
herb's Avatar
does anyone know? Could an injector pump be defective and cause to much fuel to be pushed into the cylinders?
Old Apr 7, 2006 | 02:11 PM
  #51
RustyJC's Avatar
If that were the case, I'd think you'd see black smoke and high EGTs.
Rusty
Old Apr 7, 2006 | 03:05 PM
  #52
herb's Avatar
that makes sense. i had no black smoke and no hight wgt's. Yet cummins thinks it happened because it was getting too much fuel ?
Scored cylinder walls and melting nu 1 piston = too much fuel ?
Old Apr 7, 2006 | 03:10 PM
  #53
JKM's Avatar
JKM
Is it possible your pyro is not reading correctly? A diesel pump shop should be able to put the pump on the stand and make sure it delivers the correct amount of fuel.
Old Apr 7, 2006 | 03:20 PM
  #54
herb's Avatar
300 at idle
600 emty
900 towing
1200 towing heavy up steep grades
Breakdown from cummins
7980 reman engine
2400 install
600 taxes
Old Apr 7, 2006 | 08:20 PM
  #55
Diesel-Dan's Avatar
$2400 labor?????????????? HUM........are they rebuilding it in house?
Old Apr 7, 2006 | 09:07 PM
  #56
JKM's Avatar
JKM
I am guessing they charge close to 100$ an hour , or more , and 24 hrs is not that long to pull one engine and put another one in , and get it running.
Old Apr 7, 2006 | 09:09 PM
  #57
Diesel-Dan's Avatar
yeah.....i guess your right.........MAN...im glad i can turn my own wrench when i see that........but that is a moot point.......I hope it turns out well.....let us know if we can feed any info to ya......
Old Apr 8, 2006 | 06:02 AM
  #58
turbox2's Avatar
Originally Posted by herb
Cummins called and made my day. Said have three cylinder walls scored and number 1 piston is melting.
Got gauges, nothing has been showing hot on gauges.
This is the kind of thing that scares me to death. Is it possible to have 1 piston running at 1500* and the others running at 800* and it averages out to say 975* so you never know?
Old Apr 8, 2006 | 03:24 PM
  #59
herb's Avatar
I have located these three engines. how can i tell witch one would work in my 01. two of them are for standard transmissions, my 01 is an automatic. Can i take the flexplate off my bad engine and bolt to one of these ?
235 H.P. @ 2900 RPM - 5.9 LITER
TURBOCHARGER - ECM - MANIFOLDS
STARTER: 12 VOLT - FLYWHEEL HOUSING
FLYWHEEL STANDARD SHIFT
CPL 8413 or 8412
BUILD DATE JULY 2003
250 H.P. @ 2900 RPM - 5.9 LITER
FLYWHEEL
CPL8226
305 H.P. @ 2900 RPM
5.9 LITER
TURBOCHARGER
ECM - MANIFOLDS
SAMPLE SERIAL 57070038
STARTER: 12 VOLT
FLYWHEEL HOUSING
FLEXPLATE
CPL 8213
Old Apr 8, 2006 | 04:30 PM
  #60
torquefan's Avatar
Those are all 03 and newer common rail engines. Definitely not a direct bolt-in, it would be quite a project to make your truck into a common-rail.
