Stranded in Madison Ga
Old Mar 30, 2006 | 05:31 PM
DavidTD's Avatar
Originally Posted by Bob Wagner
Herb, I gave david your phone number too. David should be in touch
Well don't I feel like a Dumb ***. I was waiting on the call. But thanks Bob for letting me know they reached Jeff. Thats who they needed anyway.
I spoke to Jeff and they were in by noon, out by 4. I understand they took a ride in the 1500 too.
Herb, let us know how it's doing.
Old Mar 30, 2006 | 06:06 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I think Herb's carriage business is just a front......
His REAL job is writing a book that will compare EVERY SINGLE business in the CONUS that works on or supplies parts for the Dodge Cummins trucks.
Old Mar 30, 2006 | 08:00 PM
herb's Avatar
If you only Knew.
He left Jeffs and drove to Vicksburg Mi and made another drop. went from there to south Mo and picked up a load of trailers. Made it back as far as South Bend Ind and brake down again.
I just got home from the drive to South bend to pull the trailers home. Will go back tommorrow and retreive the truck.
He said he was cruising along at 60 mph , good egt's good fuel pressure and it took two surge-pops and died. said oil all over engins compartment.
Am guessing turbo ?
Old Mar 30, 2006 | 08:07 PM
DavidTD's Avatar
OMG, that is awful. Let us know what happened. I don't know how many miles are on your 01, but this is my biggest fear driving any of them with a lot of miles. Jeff put a new VP44 on mine last week so I'm hoping I am good for another 100k or so.
Old Mar 30, 2006 | 08:35 PM
handymantim's Avatar
Sorry, off topic, but did you know that somebody put pictures of the Clintons on your Avatar?
Old Mar 30, 2006 | 11:06 PM
BigBlue's Avatar
I most definately wouldn't start this argument again.
So let me get this straight herb. The injection pump died and then on the way home the turbo blew? Talk about a string of bad luck. Let us know how it goes man.
Old Mar 31, 2006 | 05:18 AM
herb's Avatar
I am guessing it is the turbo, don't know for sure .
Old Mar 31, 2006 | 04:15 PM
herb's Avatar
My son is on his way back with the 01 on a trailer. He said he took the air cleaner off and looked at the turbo "impeller"? said it looked nice and clean and that it turned ok with no slop in it. Does this eliminate the problem being the turbo? He said most of the oil appears to be towards the front on the passenger side ?
Any gueses
Old Mar 31, 2006 | 04:22 PM
herb's Avatar
Son just called and told me that the wrecker that towed it in did not take driveshaft loose before they towed it. I have always been told you were supposed too ?
Old Mar 31, 2006 | 06:48 PM
herb's Avatar
will truck lose all it's power if turbo goes out ?
Old Mar 31, 2006 | 07:07 PM
Diesel-Dan's Avatar
Will loose power, EGT's will be VERY high and will SMOKE like a fright Train. A blow turbo would more than likely smoke very bad. Could be a number of things.......
Too bad that you didnt loose your clutch in Southbend, IN! hahaha......
Old Apr 1, 2006 | 06:53 AM
herb's Avatar
No Smoke, normal egt's just quit. will still start but no power.
Just got off phone with Cummins in Gd Rapids, have to take it in Mon.They said something about a pin could have came loose in gear box or something like that ?? said thay have had problems with them ??
Old Apr 1, 2006 | 08:08 AM
Shovelhead's Avatar
They might be refering to the "Killer Dowel Pin" in the timing gearbox.
Old Apr 1, 2006 | 03:55 PM
herb's Avatar
if it is that would it cause oil to spray out in the front passenger side engine compartment ? Repair cost to expect ?
Old Apr 1, 2006 | 04:17 PM
tankeryanker's Avatar
I didn't think the 01's had the KDP problem, but I could be wrong. If thats what it is there should be signs of oil comming from the timming cover do to a crack then probably spread oil all over from the fan.
