Stranded in Madison Ga
Old Apr 8, 2006 | 05:03 PM
  #61
Firedog12's Avatar
new lp truck wont start need help
Just put new lp on lp is working have fuel in filter is vp44 electric and how do I check that it has power to it? can anybody help ? not sure how to post help might be in wrong place
Old Apr 8, 2006 | 05:27 PM
  #62
Shovelhead's Avatar
Administrator / Scooter Bum
What year is the truck?
What lead you to replace the lift pump?
Did you see low pressure, or did the truck not start?
Old Apr 8, 2006 | 06:38 PM
  #63
herb's Avatar
Originally Posted by torquefan
Those are all 03 and newer common rail engines. Definitely not a direct bolt-in, it would be quite a project to make your truck into a common-rail.
i would have thought the 235 and 250 horse would nave been the older style.
Old Apr 8, 2006 | 09:14 PM
  #64
Firedog12's Avatar
2001, 0 press, truck was running till i tried to put press gage on. now has 5 psi but won't start. is it that hard to prime after opening fuel line?
Old Apr 9, 2006 | 12:10 PM
  #65
torquefan's Avatar
I didn't recognize the CPL numbers as older stuff, so mainly I was assuming it by the build dates. It is entirely possible that the 235 horse engine is the older style, but not from a Dodge. I assumed that the 250 horse engine was the Standard Output model Dodge offered in California in 03. Sorry if I led you astray.
Old Apr 9, 2006 | 06:09 PM
  #66
herb's Avatar
i am still not sure and the guy who has them does not know the applications for them. They do come with the ecm for whatever that is worth.
here is page and photo
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old Apr 9, 2006 | 07:07 PM
  #67
rammtuff's Avatar
Herb I think those are common rail engines.
Old Apr 9, 2006 | 07:42 PM
  #68
No doubt about it. Not gonna work for you, Herb.
Old Apr 9, 2006 | 08:23 PM
  #69
herb's Avatar
i am really beginning to think i am expecting too much out of these trucks.
not that heavy but a lot of wind resistance.
Old Apr 9, 2006 | 08:32 PM
  #70
I would tend to agree with you. The fueling boxes make them more fun to drive, but these things aren't mules. They will pull hard enough to hurt themselves. Run 'em without any fueling boxes and I believe they will give you good service.
Old Apr 10, 2006 | 02:49 AM
  #71
herb's Avatar
all i have is the small Edge box. Without it the truck doesn't have the power to pull the trailer
Last edited by wannadiesel; Apr 10, 2006 at 04:26 PM. Reason: symbols to avoid censor
Old Apr 10, 2006 | 04:31 PM
  #72
herb's Avatar
Cummins shop just called and quoted me 6000-6500 dollars to rebuild engine with 6 month unlimited milage warranty
Old Apr 10, 2006 | 05:13 PM
  #73
That doesn't sound bad at all. Does it include R&R or is that extra?
Old Apr 10, 2006 | 05:39 PM
  #74
herb's Avatar
R&R ???
Spoke to Channing at Geno's about the pyro and gauge (Isspro) and he directed me directly to Isspro in Portland Oregan.
Isspro said to send them the gauge and pyro and they would check it for accuracy.
I have already told them melted down two engines so most likley they will find the gauge and pyro ok.
Anywhere else i could send to have them checked?
Old Apr 10, 2006 | 06:05 PM
  #75
R&R = Remove and Replace. Is pulling the engine and putting it back in the truck included in the figure you gave?
