Started, Ran (10 seconds), Stalled, Now Won't Start........
Old Sep 17, 2007 | 07:08 PM
Vintage Empire's Avatar
This is on my '99, 2nd gen., 24 valve with 219k miles.
So I started it up this morning, it ran rough for like 10 seconds then quit. I tried to restart it a few times with no sucsess, (it turns over but wil not fire). I had a similair situation back in Jan '07, and it ended up being the lift pump. Since then no issues till now.
So I talked to a diesel mechanic today, he said it's either the lift pump again, or the injector pump. He said $1500 or $1700 for the injector pump (depending on what the vin says) and $255 for the lift pump (this is parts only)
Any thoughts or suggestions?
Old Sep 17, 2007 | 07:14 PM
rich's Avatar
first try to get a fuel pressure reading if its non existent then its lift pump but check their first before you start throwing money around
Old Sep 17, 2007 | 07:19 PM
iker42's Avatar
the bushing connecting the impeller to the motor in you lift pump is gone, EG. you need a lift pump. DOnt try to run it to avoid ruining the VP. When you turn the key to the on posistion, does it make the motor sound from the back of the engine aera?
Mike
Old Sep 17, 2007 | 07:31 PM
When I turn the key to the "on" position I don't hear anything running.
I don't have the tools to check the fuel pressure, I really limited in the tool department when It comes to this truck. I have basic sockets and wrenches but no specialty tools for working on this truck and I'm still learning about the truck and don't feel real comfortable just "jumping in".
So lift pump sounds to the problem here?
Old Sep 17, 2007 | 09:27 PM
fivefive1978's Avatar
Just got done dealing with a similar issue. The pump will only run if you bump the starter for just a fraction of a second. Then you'll be able to hear it running.
Bump the starter with the hood open then look down on the driver's side of the engine. My problem was with a leak letting air into the fuel system. You should be able to hear that lift pump running loud and clear with no fuel getting out anywhere.
Check that and let us know.
You can read over my thread here, sounds really similar:
https://www.dieseltruckresource.com/...d.php?t=168928
Old Sep 17, 2007 | 10:18 PM
jfranklin's Avatar
if it is the lift pump dont buy a stock lift pump this is a big problem area check into a fass system they are worth the money pluss they have a better filter than stock.
Old Sep 17, 2007 | 10:56 PM
johnh's Avatar
Mike
my guess is as good as your's
i say his injection pump is gone
Old Sep 18, 2007 | 09:43 PM
I had it towed to JT Diesel Perfermance http://jtdieselperformance.com/Home_Page.php last night, he called me this morning and said I had 0 fuel pressure. It ended up being the lift pump, **** thing only lasted 14,000 miles. (Please tell me more about this Fass system).
On the bright side of all of this, I did find an honest diesel mechanic in JT, he charged my $125 less than the "other" shop did for the exact same repair.
Thanks for the help everyone, much appreciated.
Chaser10
23
Feb 20, 2018 03:26 PM
MrSuzuki
Nov 8, 2008 08:07 PM
txsdodge2001
Dec 8, 2007 01:50 PM
bhallo0217
Feb 18, 2007 09:23 PM
seanvu1
Jul 11, 2004 03:48 PM
