squeeks!!
Old Apr 16, 2003 | 08:45 PM
doodah's Avatar
squeeks!!
well, I went to shut the truck down tonight and it was squeeking right at the end of shut down- it kindof did it again when I went to roll it over again. it has not done this before and it scares me! It also has ben shakeing at stopsigns alot today and I looked down and my idle was at like 400 rpms I know this is low, but would this cause the vibration and posibly the squeeking? at the stop signs it stops shaking when I step on the pedel a little bit. I do know how to set my throttle so maybe will try that first. any help?
Old Apr 17, 2003 | 04:08 PM
Smokee's Avatar
Re:squeeks!!
Hmmm. have you completed the throttle cable repair?<br>I think the squeek is the serpentine belt.<br>george
Old Apr 17, 2003 | 04:14 PM
powerwagon440's Avatar
Re:squeeks!!
i would say the squeek is the serpentine belt also! i dont know about the rpms someone else will step in on that one!
Old Apr 17, 2003 | 05:21 PM
Monty's Avatar
Re:squeeks!!
The squeek is most definately the serpentine belt. The vibration is cause by the low idle RPMs. I would bump the idle up to 750-800 RPM. Make sure you set it with the A/C on max. I bet it gets worse when the A/C is on doesnt it?
Old Apr 18, 2003 | 09:45 PM
doodah's Avatar
Re:squeeks!!
[glow=orange, 9, 900]I AM A RETARD!!!!![/glow] Crawled undernieth my truck last night, after work with it at low throttle and cuold hear it shacking and vibrating the whole truck, and what did I find? a broken exhaust hanger right next to the clamp was vibrating and rubbing on the clamp, -- welded it back up and every thing is back to normal alll except the throttles low Idle! and yes the serpintine belt was the first thing I replaced on the truck when I first bought it! -even bought a spare!
Old Apr 18, 2003 | 10:29 PM
Stamey's Avatar
Re:squeeks!!
I put a new NAPA belt on mine when I bought it. It always squeaked on shutdown. It lasted about 16K. It was pulled off when I did my KDP and about 150 miles after the KDP it started making all kinds of noise. :'( ??? <br>Belt dressing did nothing for it except spread belt dressing gunk around my engine compartment. I now remember why I HATE belt dressing though. <br>So, I bought another new NAPA belt, put it on, and now it doesn't even squeak on shutdown, if you can believe that. <br><br>Chris
Old Apr 20, 2003 | 10:25 AM
richard's Avatar
Re:squeeks!!
The idle adjustment on your truck is accomplished by looking down the back of the pump, toward the firewall. Look in the area of the transfer pump as you move the throttle. It's not too easy to see if there is a lot of crud on the engine. You will find a bolt which the throttle arm rests against. This bolt usually gets a groove worn in it from the throttle arm. You have to worm your hand between the hydro-boost lines to get at the adjustment. Forget what size the bolt is, I think maybe 12mm? <br>Hope this helps.<br>Rich
Old Apr 20, 2003 | 09:07 PM
doodah's Avatar
Re:squeeks!!
yeah, I know way to well where its at, first time i took it off and tried to adjust it the thing snaped on me so I re-manufactured it and am still dialing it in.!
Journier
Dec 2, 2009 09:14 AM
mr T
Jun 7, 2007 09:01 AM
plessm
13
Dec 14, 2006 10:10 PM
honda_guy4
15
Sep 12, 2006 10:27 AM
VikingDiesel
Mar 4, 2006 05:53 AM
