Squeek in 4wd in the front end
Old Feb 29, 2008 | 03:46 PM
granahan378's Avatar
Ok guys just recently i have a pretty bad squeek gets faster or slower depending on speed and i can only make the sound while in 4wd. Im not sure where to start as i would think its bearings but it doesnt make a sound when in 2wd. Are there any other parts to take a look at? Has any one else experienced something similar?
Thanks Kyle
Old Feb 29, 2008 | 03:52 PM
JIT's Avatar
JIT
Ujoints 1st
Old Feb 29, 2008 | 04:16 PM
TreeFarm's Avatar
Jack her up on all four. Get under it and listen for the squeak. You should be able to hear and locate it. A mechanic's stethoscope may help. Needless to say, due to the rotating stuff under there, do it carefully with a safety person present.
Old Mar 1, 2008 | 02:07 PM
DODGE4X4's Avatar
Got to be the U-Joints
Old Mar 1, 2008 | 02:52 PM
ian515's Avatar
can those make a popping/cracking noise too? thats what mine does. and how much does it normally cost to replace them? what about ball joints?
Old Mar 1, 2008 | 05:26 PM
Thanks everybody.....sure enough its the ujoints i can free turn the front drive shaft and about every half turn is a noticable squeek. Would i be better off replacing all of the ujoints, or is this not really a concern? All were very solid no wobble-the 4wd just doesnt get used to often. Maybe lube them up and see if it goes away?
Old Mar 1, 2008 | 08:16 PM
Towmaster101's Avatar
replace the ujoint and put the grease gun on it every so often.
04 Diesel
35
Sep 8, 2009 08:43 PM
stevie600
Sep 15, 2006 11:34 PM
jetmech737
Aug 19, 2006 11:07 PM
Txwelder
Jun 3, 2005 07:34 PM
Ken W
Jul 23, 2004 05:24 PM
