Smoking White
Old Oct 16, 2008 | 04:18 PM
Oscar1017's Avatar
Smoking White
hey everyone the other day i noticed my truck ('98 Dodge Ram 2500 Cummins 12 valve 4x4 auto odometer = 178XXX) was smoking white from the bottom and i followed it and discovered its from the blowby tube is this BAD Please let me know wat this could be and if it is bad or normal let me know please
I also posted thiese videos so you all could see what i mean thanks
Please let me know thanks....
Old Oct 16, 2008 | 05:07 PM
Mrlou's Avatar
Normal ,mine does the same thing 150,000 miles ,search breather tube ,lots more info. Crankcase is vented to the atmosphere so you see the vapors, gas engines have pcv valve so the vapors are routed through the engine but it is still happening. Don't overfill your oil I usually leave it about a quarter of an inch below the full mark, 10 1/2 quarts when I change my oil and filter instead of 11.
Old Oct 16, 2008 | 05:24 PM
That doesn't look excessive to me.
Old Oct 17, 2008 | 01:31 PM
Oscar1017's Avatar
oh maybe that could be it thanks again...
and so this dosnt seem like a problem??? Or is it like critical??
Old Oct 17, 2008 | 02:40 PM
1-2-3's Avatar
Just a plain ole guy
I don't see anything smoking. You might be seeing a little water condensation.
Old Oct 17, 2008 | 03:01 PM
Hillcountry's Avatar
Looks like mine too...glad to hear it is not excessive.
Old Oct 18, 2008 | 04:56 PM
Oscar1017's Avatar
oh ok thanks so this may not be like a huge problem or so like it still looks ok?
thanks aagain
Old Oct 25, 2008 | 07:50 PM
digginhiggins's Avatar
Check for vaccum leaks the vac pump will pressurize the crank case.
JamesA
Jul 12, 2007 09:03 PM
seabee
Jan 1, 2007 02:16 AM
Ripper406
Jul 9, 2006 09:26 PM
cumminsdriver635
Mar 6, 2005 10:54 AM
