smoking 03
Old May 30, 2008 | 07:40 PM
adventuris's Avatar
smoking 03
hi , truck is smoking at idle , once under way and exhaust temps go up no more smoke . thought was blown turbo had lots of play and had a whine , just replaced turbo today , truck still smoking , and noticing more timing or injector noise . what is causing this .
Old May 30, 2008 | 08:04 PM
vzdude's Avatar
DTR's 'Go to Guy'
Sure sounds like a failed injector. Hard to say though. What color is the smoke? Engine miss at all? Oil level rising at all? High egt's indicate excessive fuel. Bout the only place to come from is the injectors or something telling it to overfuel.....any codes?
Old May 30, 2008 | 08:08 PM
adventuris's Avatar
hard to tell color light blueish , no codes , oil level fine if not low truck runs fine , try to find all possiable sources before doing anything else allready did turbo which it needed .
Old May 30, 2008 | 08:12 PM
vzdude's Avatar
DTR's 'Go to Guy'
May have burned a piston then if it's blue smoke........any codes show up? Turn key from off to on * (not cranking) 3 times , ending in the on position. Any codes will read out in the odo screen. Truck have any slight miss or anything?
Old May 30, 2008 | 08:29 PM
adventuris's Avatar
no codes , check with my predator
Old May 30, 2008 | 10:00 PM
oldblues's Avatar
hi
blue smoke may be oily residue left in ex system from bad turbo seals .
run it till warm then hammer it for app 5 miles to burn out the oily junk in pipes then let us know .
Old May 31, 2008 | 01:20 PM
adventuris's Avatar
ran truck not any bettter , its worse now smells like fuel , oil level not changing , if anythin its low , have what sounds like increased injector knock , other thing i notice is truck seems to fire off faster , could this be from leaking fuel into clyinder fire off faster .
Old May 31, 2008 | 03:44 PM
vzdude's Avatar
DTR's 'Go to Guy'
Very possible. i wouldn't run it any more than absolutely necessary to avoid more damage. The damage may already be done. Find someone to help diagnose or find a good Cummins shop nearby. I'm afraid that you may have already scored a cylinder though.
Old Jun 1, 2008 | 10:02 PM
pipeliner04's Avatar
its hard to burn a cylinder unless you hammered on it and kept the egts really high for a long time,,this new ultra low sulphur diesel is the problem,,,sulphur helps as a lubricant in the motor,,,when you take it out you have problems. another problem is you and i both have an 03,,known for injector problems,,,reason being the rail pressure runs so high that the spray holes in a STOCK motor are barely big enough,,,much less when u add programs,,,my advice,,,take it to a good known cummins mechanic and have em pull the injectors and compression test it at the same time to make sure your rings arent goin down( they dont sound like they are but they gotta pull your injectors anyway might as well check that too) and if theyre bad,,,get bigger injector nozzles and you wont have any problems,,,any blowby by chance
Old Jun 1, 2008 | 10:19 PM
vzdude's Avatar
DTR's 'Go to Guy'
According to Don M.....most of the injector problems are in the later years. Like the 04.5's and up. I hope he's right at least!
Old Jun 1, 2008 | 10:26 PM
we'll see,,,keep us posted
Old Jun 2, 2008 | 07:24 PM
adventuris's Avatar
well i pulled injectors today , need to get them sent out . two of two very carboned up , number 1 cylinder i believe was leaking , when i pulled out the tubes and injectors all but one had fuel in tube or fuel go out of injector , which tells me that is the one leaking into cylinder .
Old Jun 2, 2008 | 10:02 PM
chalk one up for me!!!!cha-ching
Old Jun 2, 2008 | 10:19 PM
vzdude's Avatar
DTR's 'Go to Guy'
I'd be curious as to the results of a compression test or have someone with a borescope check it out. There may be untold damage. It could be fine too, but now would be the time to tell. I'd hate for ya to get it back together only to find out that it still smokes because a cylinder wall was scored. Any damage should be pretty evident by using even the cheapest of borescopes. Good luck and I hope I'm wrong! I just like to be thorough. Nothing I hate more than doing something twice!
jsr21
Jul 16, 2003 02:16 PM
camomullet
Mar 26, 2003 11:42 PM
da-kine
Feb 23, 2003 10:47 PM
cwbronc
Dec 11, 2002 12:36 PM
flamered
Dec 5, 2002 06:01 AM
