slave cylinder went out?
Old Aug 16, 2005 | 03:40 PM
strokethis3500's Avatar
I just installed a clutch and presure plate. Now i have no clutch at all. I'm guessing i have to bleed the slave cylinder but i dont know where to start to do that.. Any Help would be great.
Old Aug 16, 2005 | 06:04 PM
Dualler's Avatar
Clutch is bled much the same as brakes. Make sure the reservoir is always full throughout the whole process. Open up the bleeder screw on the slave cylinder and wait if fluid will start coming out. This may take up to ~ 2 min. If the gravity bleed does not work and no fluid comes out, get an assistant and do this: With the pedal depressed open the bleed screw for a few seconds and close again. The pedal must stay down till the screw is closed. Let the pedal up, wait a few seconds, then depress the pedal, open the bleed screw again and repeat as many times as necessary. It should not take more than about 10x to do this to get the air out. Do not pump the pedal violently when bleeding as this will foam up the brake fluid and slow down the bleeding process. If the reservoir runs out of fluid, you will have to start all over again.
Old Aug 16, 2005 | 08:55 PM
Dieseldude4x4's Avatar
No bleed screws on the 99 or at least not on mine anyway. When we put a new one on out at Forest City Diesel, Keith had to bleed the entire new system off the truck by letting the slave hang down low and filling from the top. Takes a while but works real well. Good luck.
Old Aug 17, 2005 | 09:30 AM
infidel's Avatar
I don't recall a bleed screw on any Ram after '93
Old Aug 19, 2005 | 05:04 PM
DZLPWR's Avatar
Im going to guess and say the slave went out on ya. Mine did about 2 months ago. Ordered a complete unit online for around 175 and put it on in about 30 mins. Comes ready to go full of fluid
Old Aug 21, 2005 | 09:53 PM
thumper 549's Avatar
or, the fork is not on the pivit ball??
Gen414
May 7, 2009 11:08 AM
cgmorgan06
Nov 15, 2007 04:02 PM
Heeler00
Feb 18, 2004 01:52 PM
Strange
Jan 24, 2004 06:45 PM
