rpm's lost
Old Jan 22, 2005 | 05:10 PM
diesel_burner's Avatar
rpm's lost
i had my truck running outside, it was about 1 degree outside at the time, i got out everything was fine. when i got back in my truck it had a check engine light on so i started looking around and my tach was reading 0 with truck still on. after that i went to dinner, shut the truck down, about 30 mins later tach was fine. so took it to the dealer and they said it had the following codes, p0341, p1690, p1693, and p0521. if any of you have had this happen to you, i would be greatful if you could help me
thanks
2002 dodge ram 6 speed HO.
Old Jan 23, 2005 | 02:38 PM
tool's Avatar
Sorry, I don't have a list of codes handy but I believe if you are loosing your tach the most common cause is the CPS. (crank position sensor)
Here is a stupid question.......
Was your alternator charging properly during this???
Old Feb 15, 2005 | 12:52 PM
ken-c's Avatar
Have you found out anything since your first post. I am having the same problem with code 0341, 1690 and 1693 and tach quits for several minutes and then starts working but no other problems occur. My alternator is working okay and I have no loss in power. This problem has only occurred when it was very cold and the grid heaters were kicking off and on and drawing down the voltage.
Old Feb 15, 2005 | 01:00 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Our Tech Facts section has a list of the DTCs here:
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Feb 15, 2005 | 05:00 PM
BigBlue's Avatar
P0341 Camshaft Position Sensor Performance / Rationality
P0521 Oil Pressure Sensor Performance / Rationality
The p1693 is a companion code meaning a code was set in the computer. I don't know what the p1690 is.
Old Feb 16, 2005 | 12:21 PM
as far as my code problem i haven't had anything else come up. how cold out side was it when it happened? what i got from mine was maybe a short or something.
Old Feb 18, 2005 | 04:27 PM
mr T's Avatar
thats why i hate when everything is controlled by sensors and computers...thank god i have a mechanical cummins...good luck!
solid_st8
Aug 5, 2006 12:23 PM
skeeter
Jan 18, 2006 03:17 PM
gcdodge
Aug 18, 2005 03:39 PM
dieselnewbie
Apr 13, 2004 12:00 AM
fishin fever
Feb 22, 2004 08:32 PM
