Rear yoke play...
Old Oct 15, 2008 | 07:24 PM
Paul S.'s Avatar
Rear yoke play...
So I thought I lost my rear pinion shaft seal as there was diff. fluid covering the underside of the bed and everything in between. I went and bought a new seal and went to replace it tonight and noticed that there is a bit of lateral play in the yoke. I checked the yoke nut and it is tight. Does the yoke need shimming, or am I missing something? Does the slinger do anything, could that be it? how much play shoud there be, I would assume none?
Thanks for the help in advance!
Old Oct 16, 2008 | 05:26 PM
Is the yoke moving independently of the pinion? That would be really weird. Seems more likely to me that the pinion bearings are toasted.
Old Oct 17, 2008 | 08:46 AM
Paul S.'s Avatar
I think the yoke and shaft are moving. I did not get a chance to get under there last night but going to give it a go tonight. If I replace just the outer bearing do I need to deal with shimming? If so I think I will have to bring it somewhere as I think that will be over my head.
Thanks
Old Oct 17, 2008 | 04:11 PM
Yes, the preload needs to be right. You need to replace both bearings, and if it's been run a while the R&P set may need to be replaced.
Old Oct 17, 2008 | 04:22 PM
Paul S.'s Avatar
Thankfully I caught it right away. Maybe only put 25-30 miles before I noticed the diff. fluid spray. I will have to take it in... I have a great place so hopefully they don't beat me up too bad on the $....
Thanks.
Paul S.
Oct 16, 2008 08:36 AM
dieselcarpenter
Sep 18, 2007 06:01 PM
ninepulls
Apr 6, 2005 06:42 PM
joefarmer
Sep 21, 2004 02:03 AM
1tuffdiesel
Jul 8, 2004 08:13 PM
