Radiator blew and I need info please
Old Jul 5, 2005 | 10:08 PM
Turbo Deeezle's Avatar
I pulled it out and took it in for repair........ small hole.
How much coolant does the WHOLE system hold and can I use the Prestone 50/50?
Also on a side note...... how much motor oil does my 98 24 valve hold?
Thanks for the past and future help everyone!!!!
Old Jul 5, 2005 | 10:52 PM
Anyone? I'm getting sleeeeeeeeeeeeeeeeeeeeeeepy
Old Jul 5, 2005 | 11:54 PM
ratsun's Avatar
I think its around 4 gallons for the coolant
and the oil its 10 liters + filter(I think a liter is close to a quart)If your mixing the antifreeze make sure you use distilled water.
Go to bed
Old Jul 6, 2005 | 08:47 AM
BarryG's Avatar
Not to confuse you any but I just replaced my hoses and coolant over the weekend. I have an 01 so it may be different but service manual says 24qts which is 6 gallons. I did not get 6 out or back in but very close to 5gals.
Old Jul 6, 2005 | 10:46 AM
Thanks for the info guys!
Old Jul 8, 2005 | 04:54 PM
strokethis3500's Avatar
oil
It holds i think 12 or 13 qts
Old Jul 9, 2005 | 03:43 AM
dsldan's Avatar
Complet system 6 gal.. but if you dont drain block and heater bout 5 will be most you can put back in. oil with filter 11 qt..
Old Jul 9, 2005 | 06:01 PM
dspencer's Avatar
I used one of the new antifreezes built for the aluminum radiators. Zerex g-05.
Supposed to last 100,000 miles? Or something like that. I figured I could run it for a couple years or 50 thousand and then check it.
I backflushed the radiator then rinsed with distilled water then filled again with distilled water. Just to be safe.
oscaroc
Feb 21, 2015 01:25 PM
8liter
Sep 22, 2012 10:19 AM
TNRIPNROR
Apr 17, 2009 01:10 AM
Magnum Salvage
Sep 19, 2007 06:06 PM
Original Junior
16
Aug 8, 2006 09:06 AM
