Quadzilla XZT+ install...
Old Apr 6, 2008 | 01:49 PM
high bid's Avatar
ok, I'm in the middle of the XZT+ install and the plugs don't seem to match up? The data link is triangular and the map plug is also? All the plugs seem to be opposite of what the instructions state. Do I need to get adapters from Quad? They weren't in the box...or does anyone have them and are not using them? Any help would be appreciated. Taking a break right now but not sure what to think. Thanks.
Old Apr 7, 2008 | 06:16 AM
donhov's Avatar
are you sure you have the xzt for the right year? On my 04.5 the plugs were self evident, including the matching color connectors. One was a 4 pin connector and the other was a 3 pin connector and they were orange and blue plugs one male & one female. Was a very simple install. If you are at the correct plugs it might be you have the wrong year unit. Call Jerramy at Quad monday am before doing anything else. They are great with their assistance and directions.
Old Apr 7, 2008 | 06:43 AM
dieselguy71's Avatar
I just saw your post on here...I thought you told me you called Quadzilla and they said it would work for you???? I asked you SEVERAL times to dbl check that it would work. Let me know what you find out.
Old Apr 7, 2008 | 06:49 AM
high bid's Avatar
I did check and from what Quad stated....99-01.
Old Apr 7, 2008 | 06:54 AM
OK...I will stand behind the sell...if it will not work I will refund your money to you..AS LONG AS IT HAS NOT BEEN MODIFIED IN ANY WAY.
Old Apr 7, 2008 | 07:41 AM
high bid's Avatar
Nope, straight out of the box as shipped. The say adapters are used for some models. I'm guessing I just need them but will post the results. Thanks.
Old Apr 7, 2008 | 09:12 AM
high bid's Avatar
ok, from what they stated, I believe the harness needs the adapters. I'm going to triple check the harness....dieselguy, you still have them around? thanks.
sCreamin400
Nov 2, 2008 01:46 PM
rsscoggins
May 28, 2007 12:58 AM
lwcmattlifter
Jan 6, 2007 01:55 PM
MikeyB
Apr 20, 2005 01:24 PM
onesourceoil
28
Apr 8, 2005 08:13 PM
