Quadzilla XZT install
I bought a used Quadzilla XZT for my 2006 Dodge 2500 (5.9L Cummins) from a seller on this board.
I installed it and the module lights when I turn on the ignition blink Green, Orange, Orange telling me that it is for my truck per the instructions and the instructions on the website. But then there is a green flash and then it goes to red. Not sure on the green flash but the red is power level 3 correct - not what I was expecting for towing and mileage. I thought it would be on the green light for the XZT but I don't know really. Any suggestions?
The module itself has DXZT2 Copyright 2005 28181 Patent Pend on it. There was a letter in the original box dated April 4 2006 discussing how this unit could be upgraded to work with the Commander for $30 so it was purchase after that date at least.
Any feedback would be appreciated.
I am pretty sure the fourth flash is like a diagnostic check type flash. If you read all the directions somewhere it metions that the 4th flash is a type odf check light and not to pay attention to it if you have a zxt.
You can use the Recon with anything. It is just gauges and will not control anything.
Those instructions came with older units but, it sounds like it has been updated if it is showing the red led when it is powered up. I would say it would work with the Commander as is.
Also it would have worked with the Commander before hand, the Commander would just not de-fuel properly.
sCreamin400
Nov 2, 2008 01:46 PM
lwcmattlifter
Jan 6, 2007 01:55 PM
MikeyB
Apr 20, 2005 01:24 PM
onesourceoil
28
Apr 8, 2005 08:13 PM
