Pulling power problem--little one.
Old May 13, 2004 | 10:09 AM
bcravens's Avatar
Hi there, I have a stock 1999 Dodge diesel. My problem is I pull a 21 foot fifth wheel and a 17 foot ski boat behind that when going to the lake. All low end power and torque is fine it's when I'm going 65 and 70 in overdrive, there is no top end power. Mainly it's when going up hills or when the AC is on or both. If I really mash down on the pedal it will shift (automatic) down but it doesn't make much gains to speed up but just holds steady until I get to the top of the hill. My question being can anyone suggets an aftermarket add on to help out with this probelm, maybe one of those power pucks or something like that.
Old May 13, 2004 | 10:18 AM
DRD's Avatar
DRD
Edge EZ or equivalent makes a big difference.
Old May 13, 2004 | 02:40 PM
4doogie's Avatar
go to www.bankspower.com and look at what they have. they have the power packs to get you over the hill
chris
Old May 13, 2004 | 03:29 PM
j-fox's Avatar
You should go to the links button at the top of this page and get some onfo from these vendors.
IMO, what you get wth Banks is overpriced. You can get this power with less $$$ . Also Banks adds use to say the mods won't void a warrantee. One word, BUNK.
Old May 19, 2004 | 09:24 AM
bcravens's Avatar
Thanks for the suggestions guys.
Old May 20, 2004 | 01:26 PM
Diesel Dave's Avatar
I had the same problem with my 5th wheel until I added the Edge EZ, now I am all
Old May 20, 2004 | 01:51 PM
nitrousn's Avatar
i had a stuck waste gate and was overboosting causing fuel de-railing. it ran good on the low and mid range under 3/4 throttle. over that it ran lazy. you might invest is some gauges to keep on top of its running.
Old May 20, 2004 | 02:01 PM
DPG's Avatar
DPG
When I added my EZ, I found that I had much more "pull" at the upper rpms than I did before. Without a load, I can punch it at 65, and I'm still being pushed back in my seat as I cross the 80mph mark. I do have larger injectors, but I had those before the EZ, and the power difference is stiill very noticeable.
DeWain
Old May 20, 2004 | 07:31 PM
J BODY's Avatar
Since you've described your truck as being able to maintain the speed, just not accelerate it seems you are at the threshold of the pulling capabilities. Of course it may be ok, but you may expect your truck to drive the same with or without the trailer like I do . I cast my vote that you would be pleased with the EZ edge upgrade and gauges.
Topper
Feb 7, 2010 10:29 PM
smokinram99
13
Mar 18, 2008 10:09 PM
Mike D
Competition / Pulls / OffRoad
Jun 21, 2007 02:52 PM
mullercarl
45
Mar 19, 2007 10:10 AM
Farmall
Apr 9, 2003 11:25 AM
