Little Loose of power APPS problem?
Old Mar 9, 2008 | 04:49 PM
smokinram99's Avatar
I have some trouble, sometimes, when cruising at low speed (soft foot on the pedal) my truck seems to lose power a bit nearly un-noticeable....if a put the pedal more down it return normally.. I'm thinking about the APPS sensor...I've red problems about it
Also sometimes, most of all when the engine is already cold, or when I have driven only 5 10 miles, it wont shift to the next gear and the rpm goes on. (too high with the engine cold) It catch about the 30mph in 2nd gear and wont shift up..
This can be related with the other problem (maybe the APPS)??
What do you think? mine 99 AUTO 84000miles on it.
ROB
Old Mar 9, 2008 | 07:51 PM
scottsjeeprolet's Avatar
Lets look at the basics first.
What's your FP? Lack of FP could cause this problem. Dead pedal is more noticeable.
the up shift problem, it doesn't shift up at all or just when it's cold?
You can always do the Apps reset, it's free, the procedure is in the Tech facts section.
Old Mar 10, 2008 | 12:31 PM
I have rebuild the VP44 about 2000miles ago...can be the lift pump?can I test the lift pump?
it not upshift when it's cold, water temp low 5/10 min of operation, but sometimes(rarely) even if I have drove for an hour or plus...
Old Mar 10, 2008 | 01:13 PM
I have found these TSB: http://dodgeram.info/tsb/2000/21-02-00.htm and http://dodgeram.info/tsb/2000/21-08-00.htm
I haven't any check light on, look for codes..
can be my problem? it's this job expensive for solve my problem?
Old Mar 10, 2008 | 10:06 PM
ontarget87's Avatar
ive got the same problem with my 99' 2500 4x4 auto 93,000. ive heard it might be the APPS, but i havent figured it out yet. keep me posted if ya find a solution!
Old Mar 10, 2008 | 10:15 PM
Mike D's Avatar
I get the same condition sometimes. I think the APPS wears over time. I've heard you can try to clean the contact pad with contact cleaner, but it's a last ditch effort kind of thing. Otherwise, the APPS will need to be replaced. There is a write up on how to clean the APPS on Cummins Forums.
Old Mar 11, 2008 | 03:24 PM
is there a test to be done to the apps? I wanna be sure this is the problem, I have seen it at about 330$!! on Hoesli Diesel store....
Old Mar 11, 2008 | 04:36 PM
Mike D's Avatar
Not sure on the test, but maybe the dealer can hook it up to the computer? My truck has around 155,000 miles, so I just ordered one from Hoesli. It's never been replace while I've had the truck so it's probably due.
Old Mar 12, 2008 | 03:51 PM
ib516's Avatar
Check the codes. Sounds like you may need a VP44 to me. Sounds like you're describing "dead pedal". If you get code P0216, you need a VP44.
Read this
Old Mar 14, 2008 | 10:05 PM
Mike D's Avatar
Installed the new APPS today. No doubt my problem was directly related to the APPS, truck drives great again with zero dead spot in the pedal. I took a long cruise on the hwy. where I usually notice the "spot" most and nothing, drove great. Hope the update helps
Old Mar 17, 2008 | 04:44 PM
No trouble codes on my 99...I'll try reset the APPS first; Mike, where you bought the new APPS? price?
Old Mar 18, 2008 | 07:34 AM
xtoyz17's Avatar
http://www.hoeslidiesel.com/specials.htm
Do a search, but I'm pretty sure you can adjust the APPS too if you find it's readings are out of whack.
Old Mar 18, 2008 | 11:37 AM
glenn-k's Avatar
For 24V APPS problems, do the Suncoast Transmission ground fix, to stop surging - locking - unlocking in most cases -- 95 % or so.
Unhook all battery grounds. Remove the 6 connector plug from the APPS at the front of the engine - lock tab on the bottom -- looking from the front the top left is the number 4 wire and is black with a yellow tracer. Cut that wire at the back an inch or so from the plug. Connect a wire to each end of the cut wire and run both to the battery ground. You need about 2 1/2 feet each of #16 ga. or so wire. Butt splice to the cut ends and 5/16 terminal to the battery cable ground bolt. Do not wire tie it to the alternator harness below the APPS.
Hook up the cables. Turn on the key and slowly depress the accelerator pedal all the way to the floor and let it back up to reset the APPS. Turn off the key.
You are now ready to go.
After multiple ground cleanings and APPS resets, this is the only fix that cured the problem for me.
Old Mar 18, 2008 | 10:09 PM
Nick02Ram's Avatar
I remember somewhere on here there is a way to set the APPS, did it for mine. Ya hae to check the voltage on a wire and at idle it should read the required mV as stated on the back of the APPS sensor.
Topper
Feb 7, 2010 10:29 PM
Leaky Gasket
Aug 14, 2008 07:17 AM
Mexstan
Sep 16, 2006 05:29 PM
JW3
Mar 15, 2006 08:23 PM
bcravens
May 20, 2004 07:31 PM
