Problems And I need help
Old Nov 24, 2009 | 12:34 PM
bigboyky's Avatar
Here's what's happening. Truck in my sig. Last week I get a CEL. It came in on the dash as a 0500 ( speed sensor I think), hooked the scanner up and got a 0341 (camshaft sensor). I cleared them and no more problem???? This morning The truck is acting starnge again. The tach went to zero, not shifting right like when at a stop sign it would die, another CEl. I get it home and the dash had 1694 & 1693. Hook the scanner up get the 0384 again. My question is will the CPS cause these problems? Thanks for the help...... Mitch
Old Nov 24, 2009 | 01:00 PM
lovinCTD59's Avatar
It sure will. Mine did the same as you describe. Your sensor may be behind the starter or under the VP44 on the back of the front cover. I know my 2001.5 has it on under the VP44. Yours still maybe be behind the starter on the block if its an early 01.
Check out your local Cummins, gonna be way cheaper than Dodge dealer...
Old Nov 24, 2009 | 06:56 PM
bigboyky's Avatar
Thanks for the response. Is this pretty much the consensus?
Old Nov 24, 2009 | 07:04 PM
rebal's Avatar
yup cps its under the vp and a bugger to get at
Old Nov 24, 2009 | 07:34 PM
bigboyky's Avatar
Ya I went and looked at it. I repaired the power steering seal and thought maybe I hadn't plugged it right. But that's something I did right.......
Old Nov 25, 2009 | 10:04 AM
bigboyky's Avatar
So anything I should know about changing this out? Just remove and replace?
Old Nov 25, 2009 | 04:54 PM
Dartsport's Avatar
According to ALLDATA, just remove and replace, put a little oil on the o-ring.
Old Nov 25, 2009 | 05:43 PM
rich's Avatar
the crank and cam run the tach
DJ Turbo.
Oct 13, 2011 09:11 PM
24valver
Apr 14, 2009 01:09 AM
dodgeram_driver
22
Dec 21, 2007 08:41 PM
coupdetat
Jan 17, 2007 09:23 AM
4doogie
Dec 3, 2006 04:31 PM
