Will not start, Help
Old Nov 25, 2009 | 05:57 PM
shovel's Avatar
I have a 2000 D/C/D auto. When i try to start it nothing. When i turn on the key, all the lights for pre start are on and turn the switch to start nothing. I have checked the lights and they do not dim. I have checked the fuse on the fender for start and changed it with the heater fuse, still nothing.I am at an RV park and need to get it going. Thanks to anyone to help me.
Old Nov 25, 2009 | 06:14 PM
GreyTD's Avatar
make sure the truck is park or neutral. check cable from batt to starter. Not sure if there is a relay for the starter. That's all I got for now.
Old Nov 25, 2009 | 06:26 PM
mishkaya's Avatar
If you're not even getting a click from the starter solenoid when you turn the key to the crank position; I would assume your gear selector is not perfectly in park. I had this issue on my '02 auto, where the selector shows park, but truck will not start. If I wiggle the shift selector, it cranks right up. Keep us posted.
TXJClark
Dec 6, 2014 05:50 AM
Hunky Dory
May 13, 2013 08:09 PM
FirstGen1991
Dec 22, 2012 04:24 PM
CoolumConst
Oct 11, 2008 10:00 PM
loosendend
Sep 4, 2006 12:01 PM
