Does not Crank, has power, will not start
A little assist here please,
1. 2003 2500 5.9 HO Turbo
2. 234K
3. both batteries 5 years old
4. all lights work and headlights dim and bright
5. throws codes:
P2607 after cleaning all battery cables and leads
P2609 before cleaning battery posts and leads
now throws both codes
turns on and will not crank, like the alarm ignition cut off is on, tried jump starting also.
worked fine yesterday, notice no problems when parked, went out today will not crank, batteries are fine, any suggestions appreciated
would bad heater grid relays cause the no crank?
2. 234K
5. throws codes:
Cummins Guru
Make sure you have the ground wire connected at the left side battery, it grounds the ECM on the side of the block. If not connected ECM has no ground. Engine will not start or crank with it off. If connected try disconnecting both ground from both batteries and letting sit for 10 minutes or more then reconnect. That will rest the WIN module for alarm.
No way 5 year old batteries are "fine", load test them single not parallel. Low battiries will diagnose with a ton of odd gremlins, just like you are having. Batteries are causing your issue, FTW.
Good luck.
Good luck.
CoolumConst
Oct 11, 2008 10:00 PM
FDX
Jan 15, 2007 01:47 PM
aaronedwards82
Jan 14, 2007 09:07 AM
PaulDaisy
Dec 2, 2006 12:36 PM
