Power bogges down over 55mph or under load
Old Jul 9, 2005 | 08:41 PM
john henry's Avatar
Question Power bogges down over 55mph or under load
idles and cranks like normal. Will accelerate normal under light condictions but under any pressure
engine bogges and choke down if I do not let off petal. Air filter clean and fuel filter changed. Fuel
appears clean. Engine has 50% power or less. Does this sound more like a injector pump problem or turbo? '97 3500
Old Jul 9, 2005 | 08:53 PM
P.J's Avatar
P.J
Any codes?
Old Jul 9, 2005 | 09:17 PM
john henry's Avatar
How do you get codes with a '97? I've had the truck 7 yrs and have not needed codes before. Thanks for any help.
Old Jul 9, 2005 | 09:34 PM
No codes, it's all mechanical.
It's a fueling problem for sure. Lift pump bad or maybe an air leak on the suction side, hopefully somebody more familiar with 2nd gens will chime in here.
Old Jul 9, 2005 | 10:12 PM
john henry's Avatar
Where is the strainer located in the lift pump? I found a diagram showing a screen in the fuel heater and prefilter assembly but can not find a diagram breakdown of the lift pump showing a strainer. Thanks
Old Jul 9, 2005 | 10:23 PM
fschiola's Avatar
You can find some help for the pre heater screen here:
Parts locations
Pre filter cleaning
The screen is not in the lift pump itself but in the preheater which is a separate unit.
One other thing that leaps to mind is that your cat may be plugged up.
Old Jul 10, 2005 | 07:21 AM
infidel's Avatar
My first thought was clogged cat also
Old Jul 13, 2005 | 01:07 PM
redramnc's Avatar
Clogged cat, weak overflow valve, or lift pump going -- you ain't getting enough fuel or getting rid of exhaust due to something.
Check fuel pressure first, it that checks out then I would suspect clogged cat.
Since it starts and idles OK it is not a slipped pump gear.
speed75
Jan 8, 2014 10:34 PM
John D
Jun 6, 2011 09:32 AM
NCFisherman
27
Feb 27, 2008 09:14 AM
hooked235
Aug 27, 2006 04:31 PM
Dodgezilla
Feb 13, 2004 03:40 PM
