Is this possible? Can it be that simple? HELP! PLEASE!
Old May 1, 2007 | 06:48 PM
Common's Avatar
Is this possible? Can it be that simple? HELP! PLEASE! (Need a part number!)
Please refer to this thread.
I think I isolated the problem.
The two solenoids that cycle the grid heaters... the one on the left was disconnected by removing the two small elbows that slide onto the studs and the problem went away and has not come back on.
The voltage needle rests at 14 on the nose...
It used to be higher like about 1/8" above 14v...
Can a bad solenoid cause the amp load I'm describing in the above thread?
Where can I buy a single replacement?
Should my voltage read higher?
Do I need both solenoids?
Does one do one thing and the other do something else?
Whats the Cummins Part Number for a solenoid?
Old May 1, 2007 | 07:51 PM
Common's Avatar
Someone please help - gotta know before I leave tonight, gonna make a stop at Cummins to buy a relay and need the part number...
Old May 1, 2007 | 08:33 PM
Common's Avatar
Got :30 minutes before I leave... pretty please?
Old May 1, 2007 | 09:27 PM
TIMMY22's Avatar
you can buy an (new) old ford starter solenoid(s).
Totallyrad
Jul 19, 2011 07:41 AM
SuperiorRam
Mar 15, 2007 03:10 AM
lawnmaniac883
Dec 26, 2006 11:15 PM
bluesurf
Feb 17, 2006 12:45 AM
1qckdodge
Nov 8, 2005 11:55 PM
