Tone ring mod....a simple 1 2 3 step by step please
Old Dec 23, 2006 | 01:33 PM
lawnmaniac883's Avatar
Ok so i have searched for the basic way to do this and have come up empty handed. Can someone post the procedure for doing this so that I can understand it? I read the crankshaft sensor thread and still dont have a clue how to do all of this?
It is my understanding that you remove the tone ring then file it down, where do i file? how much do i file? pictures would be a lifesaver....thanks
Old Dec 23, 2006 | 03:38 PM
Smokeman's Avatar
Read through this long thread https://www.dieseltruckresource.com/...ad.php?t=71543
About pg 11 or 12 "Superduty" has some posts and then has pictures in his gallery that should help you out.
Old Dec 23, 2006 | 05:33 PM
04ctd's Avatar
it's easier to grind off the side of the sensor, and turn it up in it's mount
http://s27.photobucket.com/albums/c154/cranksensor/
Old Dec 24, 2006 | 10:56 AM
ok, so just take it to the benchgrinder and smooth that part out so it can be rotated upwards? If I have position it to its full travel then timing is increased by how many degrees? Looks like what I'm gonna do, thanks.
Old Dec 24, 2006 | 11:24 AM
Ok well my sensor is smooth with an O-ring instead of offset piece so i guess grinding it is out of the question...
Old Dec 24, 2006 | 11:44 AM
04ctd's Avatar
you have to go to page 2:
http://s27.photobucket.com/albums/c1...t=DSC05282.jpg
i just ground thru the o ring area.
comparo:
http://s27.photobucket.com/albums/c1...t=DSC05255.jpg
i dunno, assume it is the same as the tone ring mod,
it's definitely a LOT of timing - it will make it stumble with a box on it (boxes add timing)
when it stumbles: mid throttle stomps to WOT with truck already rolling (coming down off ramp, let off gas for while, then stomp it, will back fart)
asked Bully dog about it - they said not to worry, and just hold it WOT all the time....
Old Dec 24, 2006 | 12:56 PM
ok ok i see now you pulled off the o-ring. Looks good will do that in the morning
Old Dec 26, 2006 | 09:29 PM
CrazyCooter's Avatar
I did both the tonring mod and sensor.
I could not tell any difference with just the sensor.
Old Dec 26, 2006 | 10:51 PM
rockittboy's Avatar
on the tone ring mod ( the way you can do it by grinding the little holes for the 4 bolts in the tone ring ) rotating it which way increases timing? i had it b4 i got my triple dog and now have too much timing i think. pops a bit when goin WOT as was stated above. i want lessen the timing, but forget which way i need to rotate it, thanks
Old Dec 26, 2006 | 11:15 PM
Tonering clockwise advances timing.
Dodgezilla
129
Nov 18, 2005 11:43 AM
BossHogg
Sep 30, 2005 06:31 PM
Dodgezilla
Sep 30, 2005 12:56 PM
Mark Hodowanec
Sep 29, 2005 09:15 PM
BossHogg
Sep 14, 2005 09:48 AM
