p0606 on 02 24v
Old Dec 26, 2007 | 03:16 PM
ScottMt02's Avatar
p0606 on 02 24v
Hey guys, my pickup started surging and sure enough I now have the p0606 code, as I search for it on the forums I find most the threads are for the 03 and up. Is this most likely due to my edge comp? The pump wire isn't tapped and the comp spends most of the time turned off. Is there a pretty good chance that I will be investing in a new ECM? I'm going to remove the edge tonight and see if that helps???
Thanks
-Scott
Old Dec 26, 2007 | 04:17 PM
bpollard1248's Avatar
didnt know whether you knew but the code is a P0606 ECU/PCM Processor. im not sure what would trigger it maybe some one will chime in on it that knows. try to reset the computer by unhooking the batteries and leave um set and see if the code comes back.. sorry i couldnt help anymore..
Old Dec 26, 2007 | 04:38 PM
bandit408's Avatar
This is what alldata says:
SYMPTOM
P0606-ECM FAILURE
WHEN MONITORED
Key ON or Engine running
SET CONDITION
Internal ECM error.
POSSIBLE CAUSES
ECM
The only fix to it is to have the dealer install a new ecm and flash it.
Old Dec 26, 2007 | 05:46 PM
ScottMt02's Avatar
Is the ECM I need to replace the one on the block? or the firewall?
The truck left me on the side of the road, and I just walked back to my house it's cold outside. I checked the codes again and now I've got 8 more to research, but i'm hoping it's all related to that same problem.
Old Dec 26, 2007 | 05:56 PM
bandit408's Avatar
on the firewall on engine side on passenger side. It is a rectangle and has 2 long wiring connectors bolted into it. It should be gray aluminum colored.
Old Dec 26, 2007 | 07:14 PM
ScottMt02's Avatar
Thanks for the help. Looks like I'm going to drop it off at the dealership tonight and prepare myself for the assault on my wallet. Didn't even make it one year between big repair bills
Old Dec 26, 2007 | 07:40 PM
jellis's Avatar
the ecm is on the engine the pcm is on the firewall at least that is where it is on mine
Old Dec 27, 2007 | 08:12 PM
ScottMt02's Avatar
UPDATE- The dealership told me it is the APPS due to all the other codes my pickup had thrown p0563, p0121, p0118, p0113, etc.... etc.. there was about a dozen of them that had tripped before it left me walking, and all these codes seem to deal with the voltage being to high. The only puzzling thing was the original code was just the p0606. Could the APPS be causing all of this mayhem??
bartholins
Jan 11, 2008 08:24 PM
kertoncol
Jan 8, 2007 06:05 PM
desertram
Jan 24, 2006 06:40 PM
fozzy777
Dec 9, 2005 09:54 PM
