Got CODES for Christmas???
Old Dec 26, 2007 | 12:23 AM
CobraCTD's Avatar
Ok, so I'm on the way to "Grandma's House", cruise set on 65mph when out of nowhere the truck drops out of cruise. No power and very limited response from the go pedal and CHECK ENGINE light comes on. I pull over to check things out, when I turn the truck off I notice it shuts down immediately (no delay from the turbo timer). Check the key three times and get P1693 Companion Code on the dash. Drive to a nearby store and notice very high EGT's and boost pressure along the way. Shut down again and checked all wiring connections or anything else that might look out of place. Unhooked and reconnected the Edge box and all returned to normal, power, temps everything. Even the CHECK ENGINE light went off. When I checked the other codes it was P0121, APPS SENSOR A.
Now I'm left wondering if my APPS sensor is on it's way out. I mean I needed to completely restore all the settings on the Edge as it was reset to factory. So was it the Edge that blinked and caused the codes, or was it the APPS that caused the Edge to blink??? Or maybe the cruise malfunctioned and caused all of it. Also, when I started up this morning, after warming up for 15 minutes, I put it in drive and was idling forward when the alarm on the Edge went off telling me my speed was 110mph. When I checked my records it showed top speed as 127mph.
No more codes and ran great all day, but don't want to get stranded if I'm overlooking something. Any ideas or opinions, or similar experiences???
Old Dec 26, 2007 | 10:56 PM
bpollard1248's Avatar
just my .02 but my 01 with edge comp did the same thing one nite but i had dead petal at about 50mph and it set the apps voltage too high and the cruise wouldnt come on... i reset the computer and it hasnt done it since thats been 2 months ago so i would see if it did it again but thats me and im tight with money. hope this helps.
BP
Old Dec 27, 2007 | 08:20 PM
CobraCTD's Avatar
Thanks for the reply. I did just that... unhooked the the chip overnight, reconnected and seems to run strong through all six levels. Only noticeable difference is cruise lags by 2-3 mph now when it used to keep speed dead on setting. Maybe check into that this weekend.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
Gypsyman
Aug 27, 2004 04:32 PM
