Oil Pressure gauge
Oil Pressure gauge
My brothers 99 auto 4x4s oil pressure gauge goes to zero pressure while driving along at speed, then back to 40+ then to zero again. It's full of oil and has 160,000 on the OD. Any suggestions would be appreciated, Also it runs fine, just like a Cummins should. Thanks
zeek:
It could possibly the oil sending unit to that gauge. That unit is mounted on the side of the block I believe on the drivers side. Mine has done the same thing on my 2002.
John_P
John_P
What John said. Sending unit is toast.
You can see it here (# 22):
http://www.dodgeram.org/tech/dsl/mt_...l_sys_comp.htm
Generally, if you have enough oil in the crankcase - you have oil pressure.
Dr. Evil:
Hey buddy, thanks alot for the nice posting of that engine schematic!
Man, that image is so clear.
zeek:
One thing I forgot to tell you. A Cummins Engine Technician advised me on my 2002 that the oil pressure gauge is NOT REALLY a true oil pressure gauge.
Apparently, the newer Dodge CTD 2nd Gen, 24 valve trucks (2001-2002) have an oil sending unit that is reading and sending a "signal only" from the sending unit to the gauge and IS NOT actually reading true oil pressure. Your truck may be different, I am not sure. My older 1996 Dodge CTD DOES read actual pressure as yours might. In my 2002 Dodge CTD I installed a REAL Isspro Oil Pressure Gauge and the readings between the in-dash Dodge gauge and my A-pillar Isspro Gauge are different all the time. The thought of not knowing what my REAL oil pressure was scared me! Especially with the way I drive and run my trucks!
I wanted to let you know about this in case you want to install another oil pressure gauge if yours is like mine.
Take care.
John_P
zeek:
Take care.
John_P
GlennRMK
May 24, 2007 10:46 PM
Matt Lambrech
Jan 28, 2007 04:13 PM
Ripper01
Apr 11, 2006 09:10 PM
streetsmoker
Feb 22, 2006 06:47 PM
