Oil leak
Old Aug 1, 2004 | 10:24 PM
farmer dave's Avatar
Oil leak
I have a oil leak that is covering the bottom of my truck. I looked around and it looks like it is coming from around the power steering pump. I tried to tighten the bolts put all where tight. I checked the fluid level and it is fine. I started looking at it more and it looks like it is coming from around the shaft that goes to the pump, I am not sure of this though. Has anyone had this similar probelm? And what is right before the power steering pump, oil pump maybe?
Thanks Dave
Old Aug 2, 2004 | 05:39 PM
apache's Avatar
I belive that would be your vacume pump. hang in there ,Ive read of this before and hopefully someone will know more and can help out.
Old Aug 2, 2004 | 06:43 PM
amartinson's Avatar
Read THIS thread. Should give you all the info you need. If it does not, post again, several of us have been through this one.
Old Aug 3, 2004 | 09:26 PM
Thanks for the replies. I think that this is my problem.
Dave
george7941
Nov 28, 2009 09:28 PM
6speedcowboy
Jan 14, 2007 01:41 AM
Iron City
Jun 12, 2006 02:37 PM
donhov
26
Jan 6, 2006 07:29 PM
PCarnathan
Aug 15, 2005 09:59 AM
