No reverse lights???
Old Dec 8, 2004 | 10:35 PM
HorseHauler's Avatar
Angry No reverse lights???
I've noticed that my reverse lights are not working any more, I've tried wigglying the shifter but they don't light up at all. I have'nt checked it out too far yet, thought I would ask you guys here what you think it could be... anyone else have this problem? thanks guys
Eric
Old Dec 8, 2004 | 10:56 PM
apache's Avatar
Fuse or, Bu light switch. That would be where I would start.
Old Dec 8, 2004 | 10:59 PM
wheres that switch at?
Old Dec 8, 2004 | 11:14 PM
LHartman's Avatar
If it's like the 47RE trans, the switch is on the drivers side of the tranny above the pan. It's a neutral safety switch.
Old Dec 9, 2004 | 06:18 AM
natstayl's Avatar
I'd bet fuse #38 is shot. Center pin (backup lites) of the trailer hitch probably was shorted during trailer hookup. It's a common problem because older trailers connectors use that pin for other functions. Keep us posted, Nat
Old Dec 9, 2004 | 07:06 AM
handymantim's Avatar
If the fuse is OK, I'd check the bulbs and then check the tranny switch.
Old Dec 11, 2004 | 12:03 AM
sorry havent responded earlier, thanks everyone for the help, i checked #38 fuse and it was burnt, so i gotta go get a fuse. thanks again
eric
Old Dec 22, 2004 | 11:13 AM
Charlie Hardin's Avatar
I had this problem with my 98, but fuse was good, switch on tranny was apparently not. Rather than mess with it then and lose a bunch of fluid, I waited till I was installing a Transgo kit to check it out. I found that the switch was misadjusted in the transmission and added an o-ring to the sealing gasket to increase clearance. Problem solved.
dsljunkie
14
Dec 27, 2018 02:14 PM
tntshrekuk
Jun 25, 2008 12:02 PM
CHarlan
Aug 6, 2003 08:40 PM
soundfetish
May 9, 2003 04:40 PM
