No Oil Pressure!!
Old Mar 3, 2006 | 06:11 PM
JimonaWing's Avatar
Question No Oil Pressure!!
Hi all,
I have a 1999 3500 Dually with the Cummins Diesel.
On the way home today, the oil pressure gauge dropped to zero and the "Check Gauges" light came on.
Is there a sending unit that should be checked and if so, how do I check it?
The truck seemed to be fine before the gauge went to zero and continued to seem fine until I shut it down.
What do I need to check to see where my problem is??
Thanks,
Jim
Old Mar 3, 2006 | 06:15 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Welcome to the site.
Nice choice of year for the truck.
The oil pressure senders have a reputation for going down for the count.
Number 22 is the oil pressure sender location.
Buy the replacement from Cummins instead of the dealer and save yourself some bucks.
It's the exact same part.
Cummins part number 3408428
Dodge part Number 5012991ab
Fuel System Components - 24-valve Cummins Turbo Diesel engine.
1. Fuel Transfer (Lift) Pump
2. Fuel Return Line (to Fuel Tank)
3. Fuel Supply Line (Low Pressure, to Engine)
4. Fuel Heater
5. Water-in-Fuel (WIF) Sensor
6. Fuel FilterlWater Separator
7. IA T Sensor
8. Map (Boost) Sensor
9. Fuel Drain Manifold
10. CKP Sensor
11. CMP Sensor
12. Overflow Valve
13. Drain Valve
14. Fuel Pressure Test Potts
15. ECM
16. ECT Sensor
17. Fuel Injection Pump
18. Throttle Lever Bell Crank and Apps
19, High-Pressure Fuel Lines
20. Fuel Injectors
21. Fuel Heater Temperature Sensor (Thermostat)
22. Oil Pressure Sensor
23. Fuel Injector Connector
24. Drain Tube
25. Intake Manifold Air Heater/Elements
Old Mar 3, 2006 | 07:21 PM
JimonaWing's Avatar
Thanks for the info Shovelhead.
I will get the sending unit ASAP.
Do you by chance have some kind of index to go the the componant picture you sent? I would be great to identify other items too.
Thanks,
Jim
Old Mar 3, 2006 | 07:56 PM
Shovelhead's Avatar
Index added to previous post.
Old Mar 3, 2006 | 08:26 PM
JimonaWing's Avatar
Thanks Ed!
btw... is there a preferred place on the web to by Cummins parts??
Old Mar 3, 2006 | 08:43 PM
Shovelhead's Avatar
Go to http://wsl.cummins.com/ServiceLocato...servicelocator
Type in your info, and you'll get the names and addresses of Cummins parts distributors in your area.
Or check you local Yellow Pages for truck parts.
Power Ram 250 C
Feb 20, 2007 11:08 AM
streetsmoker
Feb 22, 2006 06:47 PM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
