No Oil Pressure
Old Mar 27, 2003 | 06:02 PM
Contractor's Avatar
No Oil Pressure
Hello all. Have a little problem I hope someone can help with. I started my truck about 30 minutes ago and jumped my Bobcat with it. After that I got back in and my check gauges light was on. My oil pressure gauge read zero. I shut it down and waited a second. Started it again and the pressure climbed to normal then dropped to zero after about 10 seconds. Oh, I checked the oil first before the second start and it was full. Any ideas? I thought pressure sending unit, but it reads normal for a few seconds after start up.<br><br><br>Thanks <br><br>Cole
Old Mar 27, 2003 | 08:34 PM
RCW's Avatar
RCW
Re:No Oil Pressure
Check your oil pressure with a mechanical guage. I suspect you fried the old 'puter. It is best to never jump start anything with any of the Dodges built after 1993. The computers are a bit sensitive to spikes.
Old Mar 28, 2003 | 06:16 AM
Dieseldude4x4's Avatar
Re:No Oil Pressure
My gauge is acting up too. It won't come up and turns on the Check Gauges light and then goes to the max with the key off. Got to get the engine SN and get a new one from Cummins. DC wants $189 and they have to order it from &quot;CUMMINGS&quot;.
Old Mar 28, 2003 | 07:00 AM
ET RAM's Avatar
Re:No Oil Pressure
Does the oil pressure light work normal? I had a problem after an oil change. The light worked normal but the oil pressure gauge was close to zero at idle and followed the RPM's on speedup. I concluded that the sender unit was the problem. I changed it and the problem was resolved. You might have a sender problem.
Old Mar 28, 2003 | 10:51 AM
BigBlue's Avatar
Re:No Oil Pressure
I've jumped many-a-people with my truck and it hasn't had a problem. Knock on wood.
Power Ram 250 C
Feb 20, 2007 11:08 AM
streetsmoker
Feb 22, 2006 06:47 PM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
