no fuel to the injector pump
Old Jul 2, 2009 | 08:47 PM
rwstone1969's Avatar
Smile no fuel to the injector pump
shows code PO216 - help appreciated
Old Jul 2, 2009 | 08:51 PM
rich's Avatar
lift pump maybe do you have any fuel pressure gauges
Old Jul 2, 2009 | 08:55 PM
yes -
Old Jul 2, 2009 | 08:56 PM
earlier today it was around 16 psi - i had left it running about 45 minutes got into drove about 5 miles and it just quit going along
Old Jul 2, 2009 | 08:58 PM
SAVOY1964's Avatar
P0216 Injection Timing Control Circuit Malfunction
someone may know a testing procedure.
Old Jul 3, 2009 | 07:50 AM
patdaly's Avatar
Generally that's a death code for the VP.
Do you have a good LP? Should check fuel pressure. If you have fuel pressure, I got one going from advice on here, take the intake horn off and light her off using WD-40 or flammable brake cleaner. That particular truck took about 15 seconds or so of running on brake cleaner before the pump finally took over.
Do that at your own risk, I was freaked out the whole time I was doing it.
The one I did was after replacing a LP that had been dead for a while, from the sounds of it, yours is probably a IP.
Old Jul 3, 2009 | 12:27 PM
Lil Dog's Avatar
As stated, the P0216 code is the end of the line for the VP44 injection pump.
PaulS
Sep 19, 2011 07:39 AM
gablekevin
Sep 19, 2006 12:12 AM
loveturbowine
Jul 26, 2005 05:50 PM
Puke
May 22, 2003 12:18 AM
