new tranny problem
Old Feb 26, 2008 | 08:35 PM
farmerlee's Avatar
new tranny problem
ok so i bought a art carr 47re for a 98 dodge 12 v. i instaled it about two weeks ago and right off the bat under wot it would not up shift moastly from 2nd to 3rd. i callet art carr and they said they would build and ship me a new valve body whitch still hasent ben bilt or shiped last i new. now today while leaveing work it would slam in and out of gear in first whitch it has ben doing for about a week. when i first try to take off in the mornings and when i leave work so on the drive home it wouldshift fine up to od then drop in to netural then when it would pick back up it would be in 2nd and over rev it also would leave me coasting for long peroids of time after bumping the throdel and slowing down to about 20 it would pick first back up. i am so pist off about this please help
__________________
Old Feb 26, 2008 | 09:19 PM
05CTDN8's Avatar
Sounds to me like the valve body is bleeding off pressure. But I am no expert.
Old Feb 27, 2008 | 09:00 AM
dozer12216's Avatar
Is it possible a throttle cable, lever/spring, adjustment, binding, looseness, and or shift linkage is at fault???? Is it possible the cooler lines were not cleaned/flow tested???
AT this time suggest contact MR CARR for another tranny. Suspect this one is trashed by now. Clutches smoked ect.
Old Feb 27, 2008 | 06:34 PM
farmerlee's Avatar
well they are sending me a new valve body i cleared the tranny lines whith air preshure till no fluid was comeing out as art carr called for and there seems to be no adjustment on the kickdown
Old Feb 28, 2008 | 08:59 AM
dozer12216's Avatar
Adjustment where throttle cable attaches to engine.
Black Dog
Dec 3, 2009 08:18 PM
mttjma2002
Aug 27, 2009 11:09 PM
MOAGGIE
Jun 30, 2006 08:04 PM
masonic-dodge
Feb 8, 2006 05:58 AM
A-Poc
Oct 5, 2005 08:17 PM
