Need help with that pesky Powerstroke again (Vids)
Old May 10, 2008 | 12:13 PM
Common's Avatar
Its running VERY rough, will not stay running - when you floor it, the RPM's don't even climb.
Old May 10, 2008 | 02:14 PM
mikmaze's Avatar
remove cab and bed, throw away whats left, install cab and bed over rolling chasis featuring the cummins motor and tranny of your choice. not much help , but thAt sounds like one sick ferd.
Old May 10, 2008 | 04:13 PM
Dinner's Avatar
Sounds like its starving for fuel. Do you have air constantly getting into the fuel system, how old are the injectors in the engine?
Old May 10, 2008 | 04:33 PM
Common's Avatar
I really don't know how to check for prime and stuff on a Ford - the injectors are around 140,000 miles - the oil pressure gauge shows good.
It sounds like its out of time, stumbling, stalls, can't hold an idle.
It just had a cam sensor recall done, but it was doing this a little bit before - but it sounds worse.
My buddy won't buy a dodge.
Old May 11, 2008 | 10:05 AM
psd tuner's Avatar
you may want to check the connections to the injectors, remember the valve cover it the wiring harness for the injectors. it could also be the IDM injector driver module. It sounds like you have a injector problem. go to this guys page its very helpful for the powerstrokes. http://www.intellidog.com/dieselmann/home.html
Old May 11, 2008 | 10:44 AM
Night Rider's Avatar
Actualy it sounds like the cam position sensor I had to replace the one in my old 96 f250 it came with a shim as a fix from ford. Did the install and it ran like your buddy's (worse than they usualy do) got under there at 4 a.m. on the way to work and pulled it out and removed the spacer and it ran alot better. Guess the fix didn't help mine. I would take a good look at the cps if I were you guys.
Old May 11, 2008 | 10:46 AM
Oh forgot go to www.powerstroke.org and those guys might be able to help you more.
Old May 11, 2008 | 01:04 PM
Common's Avatar
Would a scan show anything?
Old May 12, 2008 | 12:50 AM
duner's Avatar
seems to me that there's some kind of a problem with the fuel crossover on those things. there's a tweak for it if that's what it is.
Old May 18, 2008 | 08:58 PM
kevellis32's Avatar
Check the lift pump. My buddy had similar symptoms like that and he needed new fuel lines and a lift pump, they also did some sort or injector cleaning without removing them. After that he said it ran just fine.
Old May 22, 2008 | 09:46 PM
dc9212's Avatar
i dont know much about powerstrokes but my dads 99 had a wire go bad that was supposably in the head and it sounded like yours does.
Old May 26, 2008 | 05:18 PM
tractorguyacb's Avatar
hmmm
That sounds like an injector issue... Did this happen all at once or did it slowly get worse. The reason why i think this is because of the blue smoke. Blue usually equals oil...
TrueBlueInBak
Dec 15, 2007 06:52 PM
Dodgezilla
14
Jul 24, 2007 06:34 AM
SOhappy
May 1, 2006 04:33 PM
Muddin03
Sep 25, 2003 09:50 AM
