2003 2500 5.7
Old May 26, 2008 | 02:24 PM
kelynack's Avatar
i removed the front driveshaft to replace u-joint on removal of u-joints , this is the back of the driveshaft where there is two u-joints ,in the middle of the inside there is a bearing , once I took this apart this berring with all its needle bearings fell apart . can i heat this part to get this piece that is pressed inside to replace it with a new bearing , and where can i find this bearing cause dodge dont list it . To them i was told i have to buy a new drive shaft. Please I need help
Old May 26, 2008 | 04:40 PM
tractorguyacb's Avatar
can you post some pics i am not so sure that i know what you are talking about
thanks, harold
Old May 26, 2008 | 05:24 PM
vzdude's Avatar
DTR's 'Go to Guy'
NAPA can get tem in some applications. Can't say if they can get it for that one or not. It is called the pivot joint in a double cardan joint. They should know what you are after if you call it that. They are a ***** to replace sometimes. You may end up having to take it to a driveshaft shop ( most heav duty truck shops could point you in the right direction ) and have the double cardan joint replaced with another one and the shaft rebalanced.
Old May 26, 2008 | 08:59 PM
rich's Avatar
if its the driveshaft that goes to front from the transfer case. the last time i priced one it was almost the same price as the u joints were
joebishop23
Oct 29, 2007 10:19 AM
03CTDCO
Nov 18, 2003 08:11 PM
shortround
Aug 22, 2003 02:50 PM
cwoodall
Nov 30, 2002 05:05 PM
jet
28
Nov 17, 2002 11:00 PM
