LOW FUEL ECONOMY
Old Jan 31, 2003 | 10:26 PM
BAD HABIT's Avatar
LOW FUEL ECONOMY
Going to CA. empty, and coming back towing. Currently 14 mpg Empty. > Fuel pressure 15lb at idle & 12lb WOT in park. New injection pump. BHAF air filter. BD box connected or not. 9 MPG towing 35ver at 70 MPH. Whats up with this. IAT replaced and clean. Do I have & where is MAP senser.Could offset keyway on I-pump be wrong one. Was sent with pump from DC. I need 18 to 21 MPG like everyone else. Any sugestions. PLEASE HELP!!!
Old Feb 1, 2003 | 12:53 AM
BAD HABIT's Avatar
Re:LOW FUEL ECONOMY
Lots of folks logged on, but nobodys talking. I'll try again tomorrow. NEED HELP. See ya.................................
Old Mar 21, 2003 | 06:50 PM
lookin4cowgirls's Avatar
Re:LOW FUEL ECONOMY
Hi all, I have a 99' CTD auto quad cab 4x4, nothing done but afe air cleaner and silencer ring came up missing, anyhow, I get 15mpg on the highway empty! and 10 in town empty, whats up with this rig, i got better mileage out of my old gasser than this new diesel! its got 115K on it now, whats killing the mileage? Also, on my way home from work it got stuck in 4th or o.d. and stalled the truck when i had to stop, when i started it back up it was stuck in 1st, and still is, > ??? > ???what kind of sensor of comp glitch is causing this headache!!! Thanks, hope to hear from you all.
Old Mar 21, 2003 | 06:58 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:LOW FUEL ECONOMY
Bad Habit, your best fuel economy is usually around 2000 RPM.
If you run at 70+ MPH you have to remember that the Ram is about as aerodynamic as a brick, so the faster you go, the worse your milage.
Try a road trip and keep the engine at low boost and 2000 rpm. You'll find your milage may improve.
Old Mar 22, 2003 | 03:38 PM
wildcard3766's Avatar
Re:LOW FUEL ECONOMY
If IAT sensor is clean, check the ect sensor resistance. It is located behind the fuel filter, on the drivers side. I regularly haul a 10k lb trailer and 20k lbs of cargo. I get 12.4 with the trailer empty and 10.8 to 11.2 loaded (depends on how much rpm's and boost I go for.) Without trailer I get about 18. I replaced my IAT and ECT sensors one day when my mileage went south.
Old Mar 24, 2003 | 09:41 AM
hvanflee's Avatar
Re:LOW FUEL ECONOMY
Sorry to show my ignorance, but what are the IAT and ECT sensors and how do they impact fuel economy? ???
Old Mar 24, 2003 | 10:29 AM
Ramflasher's Avatar
Re:LOW FUEL ECONOMY
This may not help ya, but its worth a try...<br><br>WOT in park really does not show much, and it surprises me that it drops 3psi. There just is not much of a load on it til you are in gear and pushing 7000+ lbs.<br>Try a &quot;on-the-road&quot; test at WOT. Just route the gauge from under your hood and underneath the windshield wiper, or tape it to the window.<br><br>Other things to try.<br>Fuel filter?<br>Boost hose clamps?<br>Condition of hoses?<br>Boost leaks around airhorn and intercooler?<br><br>If you have gauges, keep the boost at or below 6-8psi, and the EGTs at or below 6-700, and the rpms at about 200-2100. This should net you the best mileage. The comment about the aerodynamics of a brick is pretty much it!
Old Mar 25, 2003 | 02:38 PM
drecu's Avatar
Re:LOW FUEL ECONOMY
[quote author=hvanflee link=board=13;threadid=10361;start=0#119820 date=1048520466]<br>Sorry to show my ignorance, but what are the IAT and ECT sensors and how do they impact fuel economy? ???<br>[/quote]<br><br>Yes I would also like to know more about this ECT Sensor.<br><br>DRecu!
kawi600
Mar 13, 2012 07:22 PM
mikep_95133
Jan 28, 2012 03:25 PM
bc3
Dec 1, 2007 10:19 PM
bc3
Jun 17, 2006 09:59 PM
Haulin_in_Dixie
Jul 17, 2003 06:17 PM
