lost my brakes and steering
Old Nov 15, 2008 | 07:58 PM
FIREBUG13's Avatar
i lost my brakes and my poower steering i put a new power steering pump on it and a hydraulic brake booster and it still did not fix it can you help thank you 1999 Dodge 3/4 ton 4+4 diesel
Old Nov 15, 2008 | 11:51 PM
2stroke's Avatar
how about the vaccum pump? are u getting ANY vaccum?
Old Nov 16, 2008 | 10:49 AM
infidel's Avatar
Vacuum isn't involved in a '99's brakes or steering.
My bet is you haven't bled all the air out of it.
Jack the front up and turn the wheels stop to stop several times making sure the fluid level stays up.
Old Nov 16, 2008 | 02:32 PM
FIREBUG13's Avatar
The vaccum pump is good i still have vacuum and i jacked it up and went all the way left and right a doz times no help. it not whining or makeing a noies you thank of any to help thank you
Old Nov 16, 2008 | 03:35 PM
vzdude's Avatar
DTR's 'Go to Guy'
Is there any fluid circulating in the pump? Is the releif valve stuck? Relief valve is screwed into the back of the pump where the pressure line goes in.
Old Nov 16, 2008 | 06:48 PM
FIREBUG13's Avatar
It does not look like the fulid is moveing( its a new pump). to check the relief valve do just take the line off then take the nut out is that how u check it.is there some thing between the two pumps that could not be working it went in a little hard .thank for the help
Old Nov 16, 2008 | 08:37 PM
Dave Miller's Avatar
I believe the vacuum pump gear turns the power steering pump. There could be something broke causing the power steering pump to not turn. You probably need to tear it apart and check. Someone more knowledgable may chime in with more help since I have not done this yet...just read about it.
Try www.fixinrams.com for info.
Old Nov 17, 2008 | 10:18 AM
infidel's Avatar
Yes.
The two pumps must be aligned just right so the two pumps come together.
If there is a little space inbetween pumps and you force it together with the bolts it breaks off the gear.
Very common mistake. Take it apart and check.
Think the gear is available separately for cheap from www.fixinrams.com
Old Nov 17, 2008 | 06:15 PM
GAmes's Avatar
Did you R & R the two pumps as a unit or just the PS pump by itself?
Old Nov 20, 2008 | 08:11 AM
FIREBUG13's Avatar
IT WAS THE VACUUM PUMP THE HOLE TIME. I KNEW IT WENT IN TO GOOD. I TOOK IT OFF AND SENT IT OUT TO www.fixinrams.com $189 IS LOT BETTER THEN $2300 FOR A NEW ONE. HOPE TO GET IT BACK BY FRIDAY THE SNOW IS COMING AND I NEED TO GET READY FOR IT. I THANK YOU ALL FOR YOUR HELP FIREBUG13
Trace
Apr 2, 2009 06:42 PM
sitkarick
Jan 12, 2009 05:47 PM
EZGO1992
Nov 22, 2008 10:23 PM
mike7018
Mar 19, 2007 12:47 PM
j
Feb 22, 2004 10:59 PM
