Lost Steering and brakes (2001 Dodge ram 2500 Diesel)
Hello all,
Need help with this one. Probably caused by cold weather.
Symptoms: Bubbles in fluid, Squeeling, Louder than normal hiss from Hydroboost, jumpy steering, weak brakes. Pwer Steering pump or Hydro boost?
Just went thru a cold spell and believe something froze. Where should I start? What fluid will prevent cold WX Issues? I don't have the option of taking it to a mechanic.
Hello all,
It would be nice to find a way to really drain the system and refill just once.
Yep! I've down that when I replaced my hydroboost. I drained it into a container by removing the return hose and temporarily adding another hose long enough to reach my container on the ground. Then reattach the return long. If you get air in the system (and you probably will) it takes a lot of wheel turning and refilling to get the air out.
THANKS FOR THE HELP GUYS!!
Found the problem. It was ice in the return line which caused the pump to puke fluid. Thankfully I caught it in time. quickly bleed the system and Hydro Boost (THANKS INFIDEL), replaced fluid, will be converting to Royal Purple. That dodge fluid doesn't like the cold!!!!
Donmacky
Feb 1, 2014 06:07 PM
CumminsRedneck
Mar 18, 2010 01:05 PM
