Oil Leak!!!
Old Jan 9, 2009 | 08:35 PM
bhallo0217's Avatar
Unhappy Oil Leak!!!
Hey guys,
I just discovered an oil leak from the front end of my truck. I lost approx. 4 quarts of oil. I don't know when it started but the truck has not shown an oil puddle. I have left it parked for several days at a time and no puddle. Being a neophyte, could you guys give me some ideas of what this could be and potential costs for this? Thanks.
I'm not sure this info is necessary BUT, I just had my injector pump replaced last month and the lp replaced too. Dealership had trouble pinpointing the problem. Could an improper install cause this oil leak? Also the day I picked up the truck I burned through almost an entire tank of diesel, I took it back to find out that a fitting had not been tightened all the way down. Hope this helps.
Old Jan 9, 2009 | 10:37 PM
mini14's Avatar
might be fuel in the oil, u probably didnt burn the fuel it got pushed into the engine oil. i would smell the dipstick for diesel in it. if so driving around with that will toast the engine fast.
Old Jan 9, 2009 | 10:52 PM
Cjonnos's Avatar
C if they left the inj pump gear cover off
Old Jan 10, 2009 | 10:01 AM
johnh's Avatar
if there's no puddle of oil then do you have an oil leak?
is the oil bieng consumed? re check oil level
Old Jan 10, 2009 | 09:44 PM
bhallo0217's Avatar
I dropped the truck back off at the dealership. Once I saw the oil leak, it was pretty consistent dripping. I will let you know what happens. Thanks for the insight.
Barry
Old Jan 11, 2009 | 01:16 PM
rebal's Avatar
what color is the oil?
Old Jan 12, 2009 | 07:48 PM
bhallo0217's Avatar
Repaired
It was a split crank case valve hose. Thanks for your input guys.
george7941
Nov 28, 2009 09:28 PM
6speedcowboy
Jan 14, 2007 01:41 AM
Iron City
Jun 12, 2006 02:37 PM
donhov
26
Jan 6, 2006 07:29 PM
PCarnathan
Aug 15, 2005 09:59 AM
