Lift Pump Problem
Old Apr 1, 2008 | 08:19 PM
brummer9's Avatar
Lift Pump Problem
Hey everyone i have a 99 Dodge 4X4 quad cab Cummins. And I was wondering what are the signs of a lift pump goin out?? And the signs of a fuel pump going out?? Hope you can help me out, thanks guys
Old Apr 1, 2008 | 08:50 PM
jamie'sturbo's Avatar
When my trucks lift pump went out it would miss really bad when the rpm's went up. The faster I tried to go the more it would miss.
Old Apr 1, 2008 | 08:57 PM
91rangerturbo's Avatar
Zero smoke on start up. Down on power. Bump the starter but do not start the engine. The lift pump should run for appx 30 seconds to prime the fuel system. I am guessing you don't have a fuel pressure gauge. Pick one up to test it.
Old Apr 1, 2008 | 10:17 PM
brummer9's Avatar
Ya it still smokes during start up(just white smoke cuz its cold). I didn't think a fuel pressure gauge works on 98.5-02?? I was told that they spike up so high during start up that it would just blow the needle n wouldnt work again. Was I told wrong?? Thanks 91rangerturbo
Thanks jamie'sturbo. Mines doin that same thing with the rpms
Old Apr 1, 2008 | 11:23 PM
RCW's Avatar
RCW
Properly installed a fuel gauge works just fine. I would not have a VP pumped truck without one, they give you the critical information when the lift pump is failing so you can avoid frying an injection pump.
Old Apr 2, 2008 | 05:57 AM
Bingo. My fuel pressure gauge tacks out when i first turn the key on. But once started it is at 15psi. Unless the grid heaters kick on then it bogs to 13psi.
Old Apr 2, 2008 | 10:25 PM
brummer9's Avatar
Alright. Thanks for all the help guys. Really appreciate it
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
Hottrodjim
Oct 6, 2004 01:10 AM
Binderbound
Jun 22, 2004 12:55 AM
bkay
Oct 17, 2002 04:11 PM
