lift pump leaking
Old Apr 6, 2008 | 03:11 PM
97-12v's Avatar
lift pump leaking
My lift pump on my 97 is leaking a little under the ruber boot is it a place to tighten it up or will i have to replace it
Old Apr 6, 2008 | 06:52 PM
GAmes's Avatar
I have read that there is an o-ring in there that can be replaced. I do not know if this can be accomlished without removing the pump.
Old Apr 6, 2008 | 06:59 PM
97-12v's Avatar
thanks I will check
Old Apr 6, 2008 | 09:45 PM
RCW's Avatar
RCW
The O-ring is a stock item at NAPA. But, you do have to pull the pump and take the old O-ring in with you as they do not have a cross reference to the lift pump part number. The last one I did was 18 cents!
Old Apr 7, 2008 | 07:30 PM
97-12v's Avatar
thanks I am going to put on a airdog system but i will fix it so i will have some spare parts
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
uncleroty
Aug 16, 2004 10:49 AM
yrusoslow2
Jul 1, 2003 02:18 PM
christinyou
Mar 14, 2003 03:43 PM
