Lift Pump ???????
Old Apr 9, 2004 | 06:58 PM
DODGE4X4's Avatar
Unhappy Lift Pump ???????
Ok here is the deal, drive the truck and everything is good. Put truck into Neutral and rev it up and it sounds like it is missing and white smoke is coming out. No Engine lights are on and like I said put it in drive and it runs like a champ, blows the black smoke. This lift pump has about 65k on it and the Injector Pump is original with 92k. My fuel filter has about 12k on it could this be the problem??
Old Apr 9, 2004 | 07:10 PM
DODGE4X4's Avatar
Oh yeah I took out the Power Puck and it still does the same thing.
Old Apr 9, 2004 | 08:13 PM
MnTom's Avatar
Did you have it scanned for codes? That would be the first thing to do. Check with your local auto parts store and see if they will scan it for free. Once you get the codes (if there are any), then you can talk to a dealer for repairs.
Tom
Old Apr 9, 2004 | 08:46 PM
Scubasteve's Avatar
I would make sure your lift pump is actually providing fuel , not just making a pretty buzzing noise and doing nothing.
As far as the white smoke goes in a no load condition unless your loosing coolant I wouldnt worry about it.
If you have noticed heavy smoking under load as well as rough idling etc I would think the inj pump is fubar...
Jason
Old Apr 9, 2004 | 11:02 PM
Dr. Evil's Avatar
Tom
You dont even have to do that....with a 2001 turn your key on/off three times and end up in the on position....your odometer window will flash the codes if there are any. It may not necessarily give codes....running a box without a fuel pressure guage is a . Good luck.
Old Apr 10, 2004 | 12:01 AM
DODGE4X4's Avatar
I put my computer scanner on and it is saying P0216 Injection Timing Control Circuit Malfunction ???
Old Apr 10, 2004 | 09:52 AM
MnTom's Avatar
UH-OH. That ain't good. Just about everytime somebody gets one of those winds up replacing the VP.
Old Apr 10, 2004 | 02:32 PM
DODGE4X4's Avatar
Well I took my truck in this morning and the 65k lift pump is 100% good . But the Injector Pump is dieing so they have one on the way. I'll be back up running again on Wednesday. Thanks for yall's help
Old Apr 10, 2004 | 05:54 PM
MnTom's Avatar
Well the good? thing is there is a warranty to cover it. Good luck
Tom
Old Apr 14, 2004 | 03:05 PM
DODGE4X4's Avatar
Well the put the new VP in today and it is running great. My question is what casued my VP to go out in the first place. The only thing on the truck is a Power Puck,, I've run the truck out of fuel about 6 times but that is over a 92k miles. Just thought I would ask.
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
