leaking fuel
Old Dec 29, 2002 | 08:33 PM
doodah's Avatar
leaking fuel
i have a 97 12 -valve that is leaking fuel out of the water drain tube. the valve is shut, but it seems to leak fuel out of the tube very slowly .. but this is at an idle of about 1000 rpms {have a throttle control stick for the peddle} and yes, it is fuel, not water. any suggestions??
Old Dec 29, 2002 | 09:08 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Re:leaking fuel
I had a fuel filter do that to me, I was out of town and changed the fuel filter using Purolator brand. The O-ring would not seal on it and it would leak around the hose but looked like it was running down the inside of the clear hose. <br> A Wix filter solved the problem pronto. When I can't get a filter from a Cummins dealer, Wix will fill the bill everytime.
Old Dec 29, 2002 | 11:18 PM
doodah's Avatar
Re:leaking fuel
THANX, I WILL TRY THAT ONCE. 8)
lilsuzuki4x4
Sep 1, 2011 01:50 AM
diablo1
Nov 11, 2008 10:30 PM
txasylum
Mar 22, 2008 02:47 PM
Gumby
Jan 24, 2005 01:15 PM
