Installing a VP44
Old May 24, 2005 | 08:09 PM
muddybeast's Avatar
Installing a VP44
I have me a new rebuilt IP and the local places all want $300 for an install. I know I saw a write up on how to do it. Can someone throw up that link for me? Is this a task I should go at or should I let a mechanic do the job? Any input on the install would be great.
Old May 25, 2005 | 08:53 AM
Rammin On's Avatar
$300 is way out of line for a VP-44 install!
Old May 25, 2005 | 01:51 PM
ludwick_j's Avatar
I don't remember where the write up is, but maybe I can help. After doing it myself, I would never consider letting the dealer near my truck again. They wanted to charge me an outrageous amount.
This is what I remmeber:
Remove the fuel filter and housing.
remove the intake horn and grid heaters.
Remove injector lines in two sets of three.
Remove all fuel lines from VP44.
Remove the timing gear cover.
Make sure the keyway is at 12 o'clock.
Remove the gear from the pump with a steering wheel puller and the long bolts from the intake horn.
Unbolt the pump from the timing case and engine mounting points.
Pull the VP44 out of the timing cover. DO NOT DROP THE KEY INTO THE CASE.
Loctite the new key into the new pump. put the shaft into position so the key is aligned with the timing gear. The alignment of the key and gear is a PITA. just don't move the gear.
Slide the VP44 +shaft+key into the timing gear.
Mount the vp44 to case, then to engine mounting points.
Tighten the gear nut. (i forget the torque)
install the fuel lines.
The fun part, reinstall injector lines. #6 was really tough for me.
Reinstall fuel filter housing, grid heater, and intake.
Bleed the fuel system.
Old May 25, 2005 | 10:36 PM
farmer dave's Avatar
muddybeast,
Just curious on how much the vp44 cost you and where you got it from. I might be facing the same problem and was just wondering.
Old May 26, 2005 | 01:08 PM
muddybeast's Avatar
I purchased mine from USdieselparts.com for around $1500 and they refund around $400 when you send in your old pump as a core charge. Just about everywhere I looked had about the same price once the core was added in. Thanks for all the pointers that will help a ton.
Old May 26, 2005 | 01:33 PM
ludwick_j's Avatar
Yeah, with eoungh good pointers the job shouldn't be that tough. It took me the course of three evenings. If I did it again it would take a morning. And, I'm not very good with a wrench.
Old May 26, 2005 | 01:58 PM
infidel's Avatar
Best to have a factory service manual but these instructions will give you a good idea. It's not that hard.
http://www.nwbombers.com/membersites/kent/vp44.html
Old May 31, 2005 | 07:18 AM
Blue Man's Avatar
Back to original thread.
The Injection pump timing was bad per the dealer. They replaced the lift pump and the injection pump and now everything is fine.
Thanks for everyones input.
Old Jun 2, 2005 | 11:49 AM
ocliffie's Avatar
muddybeast,
Did you get your VP intalled
Did it solve your problems???
DieselRebel24
Dec 4, 2010 03:22 PM
Erska
17
Mar 6, 2009 09:52 PM
Jacesonne
Nov 13, 2007 12:18 AM
Smokin'02
Feb 25, 2007 08:39 PM
Timmay2
25
Feb 12, 2006 01:00 AM
