ABS and BRAKE lights
From: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
ABS and BRAKE light are coming on and off. Both at the same time. No codes set. Everything else seems normal.
Any ideas?
scratchingmyheadearlythismorningShortround out
Any ideas?
The spedo, tach, and everything works. Don't have a scanner to check codes, but the on/off check shows no codes.
Wasn't there a sensor on the front end of some of the trucks?
The lights come and go. Almost like a loose connection. Not sure how the sensor is constructed or whether it's a magnetic or optical pickup, but it acts like an intermittent signal. Weird.
Every '98 I've worked on doesn't have the key off/on feature for pulling codes.
In addition to the brake lines, there is a wire going to each front brake. Would that be the ABS sensors? Don't even have my service manuals with me.
At the house and can look at things now. This is what I've found;
Right front caliper is sticking. Noticed that going home today. It creates noise, causes the vehicle to not steer correctly at times, creates heat, and stinks. It also makes the brake pedal feel funny. I also found a very small spring, as in a coiled piece of wire, laying on the inside of my wheel, when I looked at it earlier today. The spring was ~ 1/16"/1.5mm diameter and 1/2"/12.7 mm long. Along with the spring I found some flakes of a material that could be fried nylon or brake material.
My SWAG is that the caliper has been sticking enough to creat heat and fry the right front sensor. I haven't checked the wheel bearing yet. Hopefully it was raining enough to keep everything "cooler" and possibly eliminate major damage.
Got a couple of cool ones in me and now's the time to hit the book and see if I an cipher anything.
It's raining like a cow hiking a hind leg so I can't go out and just tear it apart.
Please advise.
Shortround out
Please advise.
Shortround out
my truck has the same thing when i get on the pedal in 5x5 on the box sometimes the brake light and abs light will come on and if i hit the pedal real hard and quick it goes out right away. never really worried about it because it goes out and everything runs fine. do you guys know what that could be?
quadstar
Nov 20, 2009 05:23 PM
polaris800sp
Nov 13, 2008 05:35 PM
sssmaly
Jul 13, 2007 12:57 PM
mr T
Feb 24, 2007 06:42 AM
